Question about Weber Genesis Silver A Grill
Just replaced burners and now the valves are hard to turn on without pushing up on the manifold below. Also difficult to turn off without pushing from underneath the panel.
    President:
  • 2,777 Answers
Hello there, sorry to hear about your troubles. I can help you out here but not quite sure I understand what is going on. So you can turn the handles that control the gas, but you have to push down on the manifold below the handles? So it sounds like it's binding? Sounds like the burners may have been installed incorrectly if before that it wasn't having similar issues.
Please confirm these things,
Thanks
Tim
Posted on Jul 17, 2009
I have a 5 Burner Thermador gas cook top SGS305FS and if I am cooking something on the middle burner, and turn on the other burners to cook something else, it seems to take a long time for the other...
You need to have the gas pressure read after the gas valve while in operation to se that the manifold pressure is not below 3.5" wc for nat gas or 11 " wc for propane.
Apr 16, 2014 | Kitchen Ranges
The knob that controls gas flow to the burners was frozen shut. Ordinarily, one has to depress the knob and turn. It was not possible to do either of these. Pushed down hard and turned, and broke valve...
According to the Owners Manual, it appears to be welded. In addition, you can't replace just the one valve, it sold as a complete manifold assembly.
Sorry, I wish I had better news. If you'd like to download and print your Owners Manual go to this link.
http://www.weber.com/help/manuals.aspx
Mar 14, 2011 | Weber Genesis Silver A Premium (LP) Grill
How to replace lifters on a 360 V8 engine?
I find it hard to believe that it runs fine but, to replace either, you need to remove the intake manifold. Likely you will find both items in the lifter galley. Before dropping a lifter in there, make sure the cam lobe is still good....If the old lifter is severely worn on the cam end, likely it's not. After replacing the parts, but before replacing the valve cover and manifold, turn the engine by hand and make sure that the valve opens and rocker travel is the same as all others.
The r&r is covered in haynes and chilton manuals. One tip is to always use washers on any bolt that attaches the manifold to the heads to spread the torque load and yes, always torque any aluminum manifold to prevent warpage..
If either part has fallen into the oil pan (unlikely) it actually can stay there forever without harming anything.
Jul 22, 2010 | 1987 Jeep J-Series Pickup
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
How do you replace the valves on a Jenn-Air 720-0165
remove knobs. remove fronts of side burner/shelf by removing 4 screws each from below shelf/burner. with fronts removed, you have access to the main control panel screws. pull out main control panel, remove hoses to regulator and side burner. remove and replace valves by removing hardware and seating new burner in hole in manifold. may have to reuse hardware to install new valves on manifold. reconnect hoses, make sure valves are off, turn on gas and check for leaks with soapy water and sponge. turn off gas and reassemble. be careful with the hoses and metal gas lines during reassembly. good luck
Apr 19, 2010 | Grilling
Bryant Gas Heater goes into ignition lockout daily.
First of all try cleaning all the components inside the burner assembly, including the ignitor and the flame sensor.Try cleaning flame sensor well with steel wool or sandpaper. after cleaning check out.if the problem is same then, check out whether the manual gas shut-off valve is on and not off, and the gas lines leading up to and inside the unit all seem unmoved and undamaged. If everything is proper then remove cover from burner compartment and re-try. If ignition is successful, check for leaky ignitor gasket, or look CLOSELY for webbing inside far-right burner. It can also be caused if there is low gas presure, or a bad gas valve. That has to be checked.
To remove and replace/check the burner .follow this instructions
(These instructions apply to an upflow installation. Turn 90* in appropriate direction for horizontal orientation. Only perform these steps if you are sufficiently qualified.) Turn off power & gas supply, loosen nearest union BETWEEN gas **** & furnace. Remove wires from gas control, noting where each one belongs. Remove cover from burner enclosure & remove 2 screws securing manifold to enclosure. Lift upward/outward to disengage manifold from enclosure & carefully move aside. Remove screws securing burner set, remove burners. Inspect burners for debris in passage and runner slots. Check manifold orifices for blockage (ants?), particularly the one facing burner nearest to ignitor. If debris is present inside burner enclosure, CAREFULLY remove with vacuum cleaner. AVOID ANY CONTACT WITH IGNITOR. Re-install burner set and manifold, assuring that manifold brackets engage correctly in slots AND all orifices engage fully into burner entrance, replace manifold screws. Reconnect wires to gas control, reconnect gas supply & turn gas on. Apply liquid soap to union, check for bubbles (indicates leakage - correct before proceeding). Re-install cover on burner enclosure. Turn on power supply and check unit operation. Pay particular attention when re-installing manifold to assure proper alignment of orifices into burners.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 10, 2010 | Heating & Cooling
Gas pilot light
Most modern appliances that use gas as an ignition source do not have a pilot light. The gas and ignition is controlled by a burner assembly with a gas safety valve. In theory, the way the burner ignites is:
1. You push the start button, the drum begins to turn and the igniter on the burner assembly begins to glow.
2. The igniter must reach a predetermined current potential in order for the gas safety valve to open. Once this current potential is reached, the gas safety valve opens.
3. Gas begins to flow into the burner manifold, and you have ignition.
NOTE: It can take 30-90 seconds for the burner to ignite. As an igniter ages, it may take longer.
The reason burner assemblies are designed this way (especially in dryers) is to prevent free flowing gas from filling up the appliance cabinet without ignition. If such a condition existed, the could be a potential explosion hazard.
If you are experiencing problems with ignition, the first thing to check is your igniter. The do wear out with age and are fairly simple to replace.
NOTE: A glowing igniter does not necessarily mean it is good. If it is weak from age, it may never reach the required current level to open the gas safety valve.
If you have questions, or require additional assistance, please post back with your complete model number (located on a nameplate around the door opening on most dryers) so I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 63942 Dryer
How difficult is it to change the PCV valve. 2004
PCV is an acronym for positive crankcase ventilation.
The PCV Valve is a very common replacement item on many engines today. It's called the PCV valve for short but it stands for Positive Crankcase Ventilation. When your engine spins it many times collects pressure in the crankcase area, and it has to escape to relieve pressure on the motors bearings and seals. The PCV valve and PCV system is typically located near the intake manifold, and many times comes right off of the valve cover. It is very simple to replace the PCV valve, and you can do so by simply unscrewing it, and screwing in the new valve. We recommend using a little bit of teflon tape or paste to make sure you do not get any oil leaks.
Example (see picture below): 2,4 ltr. Audi V6 engine (BDV, AMM)
b0e80b6.png It's not difficult to replace PCV valve!
Sep 24, 2009 | 2004 Audi A4
Exahust manifold gasket, how to replace?
Hello;
The difficult part in changing manifold gaskets is getting to the bolts. It is not difficult. I jack up the vehicle and place on jack stands so I can work above, below and through the fender well. The drivers side will pull out far enough to replace the gasket without haveing to remove the manifold. You should inspect the surface for straightness. Tools needed are socket wrenches, box end wrenches and a pry bar.
Good luck and rate me highly.
Thanks;
Rich
RPM Northwest
May 05, 2009 | 1999 Chevrolet Blazer
Weber Genesis Silver A Grill Logo
54 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
