Question about XFX GeForce 6200 Graphic Card
Setup dual-boot disks, one loads VGA instead of GeForce 6200
I have an NVIDIA GeForce 6200 graphics card. The original installation works fine, NVIDIA is loaded on boot. But recently I added another disk drive and make it the primary boot drive. NVIDIA rarely loads, rather the default VGA driver is loaded, rebooting doesn't help. I have downloaded the latest drivers, uninstalled them, reinstalled them, but still they don't load on boot. However, when I boot the old drive, the NVIDIA drivers are loaded fine 100% of the time - so that means the card is fine. Any suggestions?
  • fractalman Nov 18, 2007
    I went into the BIOS and changed the PnP/PCI Primary Graphic's Adapter from "First PCIE" to "PCI Slot". Not sure if that is what you were referring to.
    Then re-booted. First time, it came up (very slowly) using the NVIDIA graphics. However, I booted again just to see what would happen, and it went back to the VGA.
    I looked at msconfig and NVIDIA is NOT in the startup list. How do I get it there?
    When I install the driver for NVIDIA, it immediately says it has to reboot. How do I disable the VGA at that point? If I disable the VGA when the VGA is running, the screen goes blank and if I reboot, it stays blank unless I boot in SAFE mode.
    When I look at the Device Manager, NVIDIA is the only one under the list of Display Adapters, but it has a yellow exclamation point, if troubleshoot, then it just says to reinstall the drivers, which I have done at least 4 times now.
    Anyway, it appears that since it isn't in the Startup menu under msconfig, then either it isn't attempting to start it up, or maybe it fails on startup and goes back to VGA.
    Thanks in advance for any response,
    I did download the latest NVIDIA drivers from their website.
    I checked and my monitor cable is plugged into the NVIDIA video card, using a VGA cable. There is another kind of connector on the NVIDIA card, but I am not using that. I also couldn't see any other VGA connector on the back of my computer.
    Anyway, I was browsing through my msconfig startup menu and disabled a number of things that I thought I didn't need:
    Reader_sl (starts up the Adobe reader - Adobe is really bad about spreading their software everywhere on a system.)
    J2GDllCmd (eFax messenger startup - which I don't need unless I get an eFax)
    NeroCheck (Only used if there are problems writing the DVD)
    PDVDServ (for a remote control of my DVD player on my computer - don't need that)
    JavaUpdate (An updater that checks once a month for Java updates.)
    Anyway, I booted and the NVIDIA driver loads and it looks good. I don't know if these changes actually helped or if this is just one of the random times the NVIDIA loaded. In any case, I am not going to reboot again so that I can spend some time using my computer. If it fails next time I reboot, I'll ping you.
  • 328 Answers
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Posted on Nov 18, 2007
  • Lyle Siemens
    Lyle Siemens Nov 18, 2007
    Something to try: Your VGA has a port and your video card has a port in the back to plug in. Change the cable from your VGA to your video card port before rebooting. If you have done this, let me know. Are the drivers new from NVIDIA's website? There may be a new version with a patch available. We will get it sorted out.
  • Lyle Siemens
    Yes a software conflict may have happened too. Good luck and if any problems, just ask. Good luck.
Nvidia geforce 6200 graphics card choppy/unrolling images/scrolling
dont use new drivers, just use the original driver that came with the cd when you bought the videocard.
or better yet, try to use a wddm driver.
Feb 29, 2012 | Nvidia GeForce 6200 AGP Graphic Card
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
EVGA GeForce 6200 512 MB card + mouse pointer
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here
Jan 06, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
EVGA e-GeForce 6200
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
I have Nvidia GeForce FX 5500 / 256MB DDR / AGP 8x / DVI / VGA /
try downloading " Driver Magician ". This searches for and updates all drivers on your system. There is a small fee for registration but this has been a God-send for me.
May 04, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Card seems to be defective - slow, reboots, fails on resolution change
If Windows is continuously loading up to 800x600 then your drivers are not being installed. Are you using the the 169.21 Nvdia Forceware package? What OS?
Jan 09, 2008 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
XFX GeForce 6200 Graphic Card Logo
146 people viewed this question
Top XFX Computers & Internet Experts
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
