Question about Proscan PS61670 61" Rear Projection Television
Picture looks like it is 3D
The picture looks like a 3D image. Its like all the colors shade thereselves. Seems like some sort of alignment problem with the colors
  • Proscan Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See bepicture looks like it is 3D - 69189a5.pngix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
Image is showing in all three colors
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts must be change on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Sony KP-46WT500 46" Rear Projection...
The color is distorted and the images on the screen is double.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-65WP55 65" Rear Projection...
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
127 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
