Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Took my 6347D apart to replace change lever(drill/screw) and now forward/reverse are backwards. Thought I reassembled all parts properly???
  • 26 Answers
Just swap the connection at the motor's ****..
Posted on Aug 05, 2009
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Regards
Mar 01, 2016 | Health & Beauty
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
Motor operates but drill has no power forward, only reverse.
you have a problem with the switch or the reversing lever. If you go to take it apart use caution that you do not disassemble the gear mechanism, you can find a breakdown and buy parts from them direct or they also have a locator at makitausa.com. I would look at the breakdown before trying to disassemble.
Aug 01, 2011 | Makita 8443DWDE Factory Reconditioned 18V...
How to change the drill head
If you man changing the chuck, take out any drill bits and look down into the chuck. You will see a screw holding it on. On many drills this screw has a reverse thread so it loosens in the opposite way to regular screws. You have to undo this screw to remove the chuck, then fit a new one of the same spec or one suitable for the drill and reassemble in reverse order.
Mar 31, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My son's gator will not go in reverse anymore.....When we first got it it did but as soon as we removed the screw for 2nd gear, it stopped....why
The problem is with the red forward/reverse switch. The two speed switch only works once the red forward contacts are engaged. I had the same problem several years ago. Replace the red switch and you are good to go.
Jan 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Wii Drive Levers
Without the springs your pretty much screwed. They are kind of important in the grand scheme of things. Without those springs you won't have to worry about reassembling it. If you find them, here is a Wii dissasembly guide. Follow it backwards to reassemble. http://www.xbox-modchips.com/wii-tutorials/xcm-wii-dissasembly-guide.htm
Nov 26, 2008 | Nintendo Wii Console
Bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Oct 18, 2008 | Bosch Drills
Model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
Sep 12, 2008 | Makita 6932FDWDE 14.4V Impact Driver
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
115 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
