Question about Polaroid Portable DVD Player PDM-0822BD
My dvd player doesn't spin - Polaroid Portable DVD Player PDM-0822BD
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My panasonic dvd rv31 player starts to read the disk like 3 times then flashes a code HO2. What does that mean?
This errors usually happens because the spindle(The thing that spins the DVD), isn't moving properly. You can try this to see if that will fix it:
1) Eject the tray, and unplug the unit with the tray out
2) Remove the case
3) Locate the spindle, and spin it gently a few times
4) Put the cover back on and see if that fixes the issue
If that doesn't fix it, then the spindle will need to be replaced
Sep 12, 2012 | Panasonic Televison & Video
DVD Player doesn't recognize disks present
Get a DVD cleaning kit and follow instructions, if this fails the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to buy.
May 08, 2012 | Yamaha DV-C6480 Multi-disc DVD Player
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
Polaroid Portable DVD Player PDM-0822BD Logo
230 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
