Question about Miele Washing Machines
Miele WT2670 message on screen "waterproof system activated". How do I reset?
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Posted on Aug 01, 2009
  • 6 more comments
  • ajsbsa Dec 07, 2010
    Brilliant advice worked a treat
  • ALsy933 Feb 04, 2011
    Ditto, worked first time and instantaneously
  • rustworker Feb 18, 2011
    Worked straight away for me too. Thank you.
  • moscowfix Apr 04, 2011
    THANK you, indeed!!! Worked stright away. :o)
  • stewartholfo Jul 02, 2011
    Thanks, that has just saved me a £105.00 call out!
  • Indian Hero Aug 26, 2011
    Perfect - worked beautifully - why don't Miele just tell you to do that in the first place!!
  • Kaja Feb 17, 2013
    It is the perfect advise, thank you very, very much!!!!
  • Matthew Clayton
    Matthew Clayton Oct 27, 2013
    Perfect, worked first time....last time I called the Engineer out and he was charging me as it was not a fault with the machine but a block in the drain pipe which was not covered by the warranty!! Thanks to this tip I now know what to do
Worked for me too... thank you so much for your advice...
Posted on Mar 11, 2011
I have a Miele W 2389. Message saying waterproof system has activated. Turn off stop ****. What does it mean?
Hi Dear. Seems like your machine had internal leak. Float switch has been activated. That triggers error message on the display. What you can do is: Tilt the machine 45 degree (Back or forward which ever easy for you) wait for leaked water come out underneath the machine. If water comes out of machine, it's a indication of one of the plastic component failed(it could be drain hose- tub to pin trap hose- may be inlet valve etc....) If there is no water coming out of machine, float switch may be malfunctioning. In that cases you need to contact Miele center to get help.Thanks.
Apr 17, 2016 | Miele Washing Machines
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
How do i remove the lid of a miele wt2670 wasing machine
Two small screws at the back and one on either side (behind little covers)
There are two hinges at the back, so lift off from the front up.
Aug 28, 2010 | Miele WT945 Front Load Washer / Dryer
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Feb 16, 2010 | Miele W2203 Front Load Washer
Water protection system activate - how can i deactivate?
how do you fix machine when waterproof fault comes up even after draining machine?
thanks Linda
Aug 23, 2009 | Miele W4840 Front Load Washer
Wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
3,745 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
