SOURCE: Reluctant to start
problem is almost certainly the door interlock. to replace, remove the plastic clip holding the door boot onto the cabinet and peel it back adjacent to the door lock. the door lock is just held in by two screws accessible at the front of the cabinet. not an expensive part. easy job - takes about 10 min
SOURCE: washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
SOURCE: Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
SOURCE: bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
