Question about Dryers
Dryer was running, son took out clothes slammed door shut, now won't start. Any solutions!!
  • Mike Smith
    Mike Smith May 11, 2010
    Sounds like the actuator for the door switch is broken . What brand and model number ?
    President:
  • 1,273 Answers
Hi. That's a pretty strong son you have there! But seriously folks.... Unplug the dryer. Check for loose connections (screws) at the latch and catch. Tighten up anything loose. If this doesn't get you up and running test the switch for proper operation with an electrical meter. Also check for loose wiring connections at the switch when you go to test the switch itself.
Regards, --W/D--
Posted on Jul 17, 2009
Zanussi dryer tc7114W door shuts blows the fuse
Behind the door locking mechanism is a switch, it sounds like from the force a wire might be touching the inside of the machine chassis. Gain access to the back of this switch and check there are not loose cables or cables touching metal.
You should be able to access it by removing the top of the machine, remove the 3 screws and tap the front of the lid with the but of you hand to knock it back and remove it. With a torch look down the inside from of the machine to idenfiy anything loose. Alternativly remove the back of the machine and see of you can see it that way, as that model does have quite a large back access panel.
Keep your screws safe ;)
Oct 03, 2012 | Zanussi TC7114W Electric Dryer
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Aug 17, 2011 | GE DVLR223 Dryers
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
Door will not close
Believe it or not the door sometimes needs to be slammed - try it and see if it works - if not the lock needs to be aligned with the latch
Sep 11, 2008 | Miele Novotronic Premier 500 Front Load...
Won't work at all,
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Nov 02, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
