Question about Panasonic AJ-P2COO8HG for AG-HVX200 (AJP2C008HG)
Firewire 4 pin connection is npt reliable with my firestore fs 100. Can I fix this myself?
  • 126 Answers
Hello there!! I think that you mean that the firewire connections is faulty with alot of errors during rec.This is caused by many movements in the cable and so the connector after a while gets loosen. I mean the 4 pins inside it. Therefore you should replace the 4p connector .You need to have experience in replacing connectors like this,not so easy though. Another solution for this kind of problem is to put some kind of glue around it so when it gets solid no more movements will happen again, but this is not the real solution.
Posted on Feb 02, 2010
Update firmware to firestore fs-100
salve, volevo trasformare il mio firestore fs100 dte da NTSC a PAL. ? possibile tramite firmware?
Sep 14, 2013 | Focus Enhancements FireStore DVCPRO HD...
I had format my Fs-4 Pro HD, and I need that file... can i recover that file from FS-4 Pro HD
there are several recovery softwares available, but none of them can gaurantee the file to be recovered 100%. you can google for "File Recovery softwares". many will give you the option of a trial version.
Mar 28, 2010 | Canon Firestore FS-4 Pro Edition...
Unit re-powers after being turned off. Only removing the battery gets it to shut down without re-powering.
When it repowers,is it because when you hold the unit,it repowers? Then once it shuts down put the unit down.
Feb 15, 2010 | Focus Enhancement FireStore FS-4Pro HD...
Connections
see if ur both devices ur laptop and ur camera has firewire 1394 port it is like mini usb port but check out the pins is it 4 pins normally it is 4 pins it is called firewire cable then u can connect directly ur camera to laptop and capture thru firewire port if u dont hv firewire port in laptop or camera let me know we can work on other ways after connection contact me for further instructions of cap video on pc
pls rate me FIXYA if i fixed ur problem
pls reply with camera model and laptop model u have
Mar 07, 2009 | Panasonic NV-DA1 Mini DV Digital Camcorder
Connecting the Canon FS 100 to my iMac
jhobby2000 buy a usb 2.0 specially for SD or SDHC chip
Dec 31, 2008 | Canon FS100 Digital Camera
Firestore FS-4 does not show up when connected
I own three FS-4 and one of them has the same problem. Two of them connect no problem. The third one says the connection is successful but windows doesn't recognize it. After playing around a bit it appears that I am not getting a good connection with the 6 pin firewire output on the Firestore. I find that with repeated attempts and carefully holding the cable in various positions, I eventually get it (reminds me of analog TV antennas when you have to be in just the right position to get a channel in clearly). The good news is, once it is recognized, it stays recognized until the need for the next download.
So for my unit, I think I simply have a bad jack. Hope this helps.
Lance
Nov 19, 2008 | Focus Enhancement FireStore FS-4 Pro...
Firestore FS-4
Try a factory reset - it will probably fix the problems you're seeing. These are the instructions I got from Focus Enhancements: FACTORY RESET
a. With the Firestore powered OFF.
b. REMOVE the “battery” and connect the “AC Adaptor”.
c. Press and HOLD down the "ON” and “OFF” buttons for 15' seconds, then release just the “ON” Button.
d. Count to five (5) then release the “OFF” button.
e. The Firestore should be powering back up to the home screen.
(It takes the firestores settings back to the normal setup. This "will not" erase any current footage on the drive) (You may have to re-do current update/upgrade version)
Aug 10, 2008 | Focus Enhancement Firestore FS-4 Hard...
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
Panasonic AJ-P2COO8HG for AG-HVX200 (AJP2C008HG) Logo
69 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
