Question about Samsung Cell Phones
Dropped my phone in water
Stayed in for 30 seconds
  • 389 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the phone got wet and exposed to liquid, it needs service. It will lead to corrosion that may damage the phone’s mother board.
Posted on Jul 18, 2009
Water temp gauge works for about 30 seconds and then drops to zero
Most likely have a bad DIM. You may start to see the SRS light start coming on and the speedometer may stop working.
Nov 29, 2015 | 2002 Volvo S60
Turn phone, type in password and it just reboots
Possibly damage to electronics inside
Water? - Drop phone in a bag of rice for 12 Hours.
Hold the Top Key and bottom round key down
10 seconds does a reboot
if it restarts again... I would suspect water or internal damage
Last Resort
30 Seconds + puts it in recovery mode where you need to plug the power / USB cable into a computer running iTunes.
Itunes will try and install clean software.
Finally
Take it to an Apple Store Tech
Even if it's only for a trade in
Sep 21, 2015 | Apple iPhone4 4G iPhone 4
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Drop in water didn't turn on
Dear Brother:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 07, 2012 | Cell Phones
MY TOUCH SCEREEN IS FREEZE WHAT DO I DO...TYPE MY CODE IN...I NEED HLEP
just press the power button with out letting go for 30 seconds or until the phone turns off then turn it back on
Feb 11, 2010 | Samsung Instinct Cell Phone
Propel Dropped in water. Now the screen's blue and green
I put mine in a seal bag of uncooked rice for a day (to absorb the moisture) and then tried this solution and it worked!! Good luck
noavatar_s.gif N1XGamerGod
Rank: Guide
Rating: 78%, 14 votes
Okay heres what you do guys!!! Just happened to me today and I fixed it. Mine was at the bottom of a hottub for 2 days XD.
The power in the phone needs to run out
then, plug the phone up
wait about 30 seconds(download screen should be up and it is charging xD.)
Then Take the battery out and unplug the charge from the phone
Stick the battery back in
Wait about 30 more seconds
Hold down the Red Phone untill it turns on.
FIXED! YAYYYYY!
Aug 14, 2009 | Samsung Propel A767 Cell Phone
Katana II likely water damage... Help!
Take the battery off, unfold the phone, set it in a warm, dry place and pray like heck. plugging it in may help it stay warm but leave it off.
If its minor water exposure it'll likely be fine in 2-3 days.
Mar 02, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Razr v3t wont stay on
If you have access to the Motorola Phone Tools software, I would update your phone through it first to make sure you have the most up to date firmware.
The next part may be tricky with the limited amount of time before the phone turns off, but I would try to reset the phone through the settings menu. Make sure you backup your data before doing this, as it will wipe the data from your phone.
This can often be caused by a bad SIM card as well. Most phone carriers will replace your SIM for free. Maybe try popping in a buddies SIM card and see if the results change.
Dec 12, 2007 | Motorola Mobility RAZR V3
Phone wont shut off
Sounds like water damage or keypad bad.
Jul 23, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
83 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
