Question about Sony CDX-CA400 CD Player
SONY EXCD-206 December 1996
Ineed a wiring diagram for this model Sony car radio/CD player . OR at least the power wires ,the speakers I can figure out.
Re: SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Posted on Mar 08, 2009
0 characters
3 Points
Wiring diagram for cdx-gt450u
You may download the instruction and installation manuals from here. The wiring diagrams are on the first page of the installation manual.
Nov 29, 2012 | Sony CDXGT450U Car CDMP3 Player
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
Stereo wiring codes
if you take a 9v battery, and touch it to the speaker wires, you can find out which wire goes to which speaker, OR you need only 3 wires ( memory, power, ground) to power the radio, then you should be able to figure out which are the speakers, or attach a speaker, and use fader and balance to figure out which channell that is on the radio
May 15, 2009 | Sony CDX-FW570 CD Player
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
If you are looking for wiring diagram of CDX-F7005X..
Click Sony Support to download required wiring diagram.
If Sony car stereo model is different, let me know to help you out.
Feb 14, 2009 | Sony CDX-F7005X CD Player
1991 chevy s10
It doesn't need an amp, it has one built into the radio. You may have it wired wrong. Please tell me what color the wires are coming from the radio that you have connected to the speakers. Each channel has it's own color, with the black stripe wire being the negative for each channel. Example: the gray wire is positive for front left speaker and the grey with a black stripe is the negative for the front left. Make sure that none of your speaker wires are grounded to the chassis.
Jan 03, 2009 | Sony CDX-L510X CD Player
CDX-M610 CD Player
Constant 12 volt is yellow,switched 12volt is red. Mix these two up and you'll lose your presets everytime you turn your car off. Ground is black. Sony uses gray,green,white, and I think purple for the speaker wires. You'll have green and green with a stripe going to one speaker and so on. Check out, you can print off wiring diagrams that are model specific...
Mar 18, 2008 | Sony CDX-M610 CD Player
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
Sony CDX-CA400 CD Player Logo
890 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
