Question about Electronics - Others
After compressing the mmc it shows only 511 mb?
Hi My 2gb microsd memory card only offers 1.87gb of free space when its completely unused. So i fiddled around with it on the pc (windows 95) and when I saw the properties for the mmc there was a small tab labelled compression on the right, so when I compressed the mmc using Drivespace it said it will creat a host drive and my total memory after compression will be 2.7GB but after compression I only found 511mb of total memory! not even my original 1.87GB so i formatted it again and now im back to 1.87 GB.
I'm guessing after compression when i checked the mmc on pc it only showed me the host drive not the main memory?
I'm real confused on how to make this work.
Please help!
Thanks alot for your time.
  • 2 more comments
  • bumboola
    bumboola Nov 18, 2007
    BTW its a Kingston Microsd mmc, if that helps.
  • bumboola
    bumboola Nov 22, 2007
    Hey Philip thanks for your solution but I still am confused about this, is there anyway to use both the master boot and the normal memory together?
    I want to be able to make the 1.87 gb to a whole 2 gb usable on my nokia.
    Thanks
  • bumboola
    Thanks Philip so then whats the point of Disk compression why have it at all if its no use?
    So Is there anything else I can do to increase my memory?
    Regards
  • bumboola
    WOW Philip thanks alot firend that made me understand that its better not to compress the mmc!
    Thanks bro
    FiXya!
    Novelist:
    Champion:
  • 244 Answers
All the storage device are being filled by a hidden file which is called master boot record (MBR) Meaning to say that some of the bytes are being allocated to used for such file. Sorry but you don't need to worry about its a normal bytes your got in your memory card.
Please rate me SOLVED If you got the solution.
Best regards,
Philip
Posted on Nov 19, 2007
  • 1 more comment
  • Cheater Cheater Nov 22, 2007
    There is no way to use it, since master boot record are being used with a purpose such as auto detect when you plug to a certain device in order the device will able to recognize your memory.
    You can only identify the hidden file or mbr using disk manager which you can see all the hidden file used with your memory.
    Disk compression takes advantage of (at least) two characteristics of most files. First
    is the fact that most files have a large amount of redundant information, with patterns
    that tend to repeat. By using "placeholders" that are smaller than the pattern
    they represent, the size of the file can be reduced.
    For example, let's take the sentence "In fact, there are many theories to explain
    the origin of man.". If you look closely, you will see that the string "
    the" (space plus "the") appears in this sentence three times. Compression
    software can replace this string with a token, for example "#", and store the
    phrase as "In fact,#re are many#ories to explain# origin of man.". Then, they
    reverse-translate the "#" back to " the" when the file is read back.
    Further, they can replace the string " man" with "$" and reduce the
    sentence to "In fact,#re are$y#ories to explain# origin of$.". Just replacing
    those two patterns reduces the size of the sentence by 24%, and this is just a simple
    example of what full compression algorithms can do, working with a large number of
    patterns and rules.
    The other characteristic of many files that disk compression makes use of is the fact
    that while each character in a file takes up one byte, most characters don't require the
    full byte to store them. Each byte can hold one of 256 different values, but if you have a
    text file, there will be very long sequences containing only letters, numbers, and
    punctuation. Compression agents use special formulas to pack information like text so that
    it makes full use of the 256 values that each byte can hold.
    The combination of these two effects results in text files often being compressed by a
    factor of 2 to 1 or even 3 to 1. Data files can often be compressed even more: take a look
    at some spreadsheet or database files and you will find long sequences of blanks and
    zeros, sometimes hundreds or thousands in a row. These files can often be compressed 5 to
    1, 10 to 1 or even more.
    Finally, compression is also useful in battling slack. If
    you have 1,000 files on a hard disk that uses 16,384 byte clusters, and each of these
    files is 500 bytes in size, you are using 16 MB of disk space to store less than 500 KB of
    data. The reason is that each file must be allocated a full cluster, and only 500 of the
    16,384 bytes actually has any data--the rest is slack (97%!) If you put all of those files
    into a compressed file like a ZIP file, not only will they probably be reduced in size
    greatly, but the ZIP file will have a maximum of 16,383 bytes of slack by itself,
    resulting in a large amount of saved disk space. The advanced features of DriveSpace 3
    volume compression will in fact reduce slack even if file compression isn't enabled.
    Welcome, thanks for the rate.
4gb card showing 30.1 mb unable to format
my sd card is of 2gb but its size is showing only 45.6 mb
please give me solution on sandip.955@live.com or on 9560709358
Nov 10, 2011 | SanDisk 4GB microSD High Capacity Memory...
How can i renew or erase my password on SanDisk microSD memory card if it doesn't appear on my computer and phone? it always says "please insert a removable disk to drive (:E) what to do? :(
Good Day, Possibly the MMC is corrupted already. but before you end up buying a new one try looking for this kind of gadget, if you have friends that have this you may just borrow this once10_30_2011_2_52_44_am.jpgThen just plug in your Memory card here, then plug in to a computer, the computer may show no activity,just let it be, the device will blink a few times, then it should be a steady light afterwards. after that the process is done. but if the device does not steady its lights the MMC is broken, or if the process is done but still password is asked.
This process completely resets the MMC so no data can be restored.
Hope this helps you.
Sep 05, 2011 | SanDisk 2GB microSD Memory Card
I have 8 gb mmc and im unable to format it on my pc as it shows no card and i cant even format is through my phone it shows mmc corrupted
Hi there and welcome to fixya,
That's a common problem with MMC's... here something that might help:
Use a pencil and erase the contacts of the MMc card, this will reveal the shine on the contacts. Try replugging it again.
I sincerely hope this would work out in your condition,
Dec 27, 2010 | SanDisk 2GB microSD Memory Card
I forgot the password of microsd mmc in nokia3110c
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
May 08, 2010 | SanDisk 2GB microSD Memory Card
I forgot my password of my 2gb microsd memory
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
Please rate this solution, if it works
Rnj VinodKumar
Mar 10, 2010 | SanDisk 2GB microSD Memory Card
NOKIA 3230 with RS-MMC card 512 mb.
scan the mmc with the good virus scanner
Oct 31, 2009 | Nokia 3230
My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
Aug 28, 2009 | HTC P4350 Smartphone
2gb sd card but available only 1gb
levyveress,
Well you have a 1GB SD card, there are roughly 1,073,741,824 bytes max per gig. They vary slightly from USB flash drives it total bytes, but the number should be 1,930 (or something close) MB for the 2Gig SD card, bring it back it may have been mislabeled on the packaging.
randy320sgi
Jan 17, 2009 | SanDisk 2GB microSD Memory Card
Receiving directly to memory card
if you want to recieve data on your phone above the free memory space, first try to transfer your files that was saved on your phone memory to memory card. or on safer way if you want to download data use mmc reader for downloading.
Mar 03, 2007 | Nokia 3230
Electronics - Others Logo
187 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
