Question about Sony KP-57WS500 57" Rear Projection Television
My Sony tv has a problem the screen turns green color
  • 250 Answers
More typically, these color uniformity problems occur without respect to which input or cable is used. The one exception is when a bad component cable or component cable connection disturbs the color.
If you're only getting the problem when viewing through the set-top box and HDMI cable, you may try changing the cable, having the box inspected or replaced or tweaking the many XBR1 custom color settings for that specific input.
If you are experiencing a genuine color uniformity issue such as the green haze problem regardless of input after allowing the set a reasonable amount of time for warmup, you may not be able to get it fixed to your satisfaction. Sony's "cure" in most cases has been to replace the optical block. Last I heard, this major component was on back order.They're going to want to do a service call on your set first, of course. If they look at your set and tell you it needs a new OB, I wouldn't waste time being put on a waiting list for the new part. That may never happen, or at least not in a reasonable timeframe. OB replacements don't always go smoothly either; it's a major repair requiring good technician skills. Best bet: go for the XBR2 swap, as a few others have done.
Posted on Jul 17, 2009
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv screen turns green
Use the remote control to go into your TV picture settings menu and change the mode to NATURAL. It's also a good idea to check that all of your cables are in good shaped and tightly connected.
The green color could signify that your TV is magnetized. This can cause colors to draw out to the corners of the screen. Remove any magnetizing devices, like speakers, away from the TV and see if that helps.
For more solutions, read the troubleshooting steps outlined in TV color problems. I hope this helps!
Sep 12, 2012 | Sony Internet TV NSZGT1
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
516 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
