Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I have a Kenmore refrigerator with a bottom freezer. The unit has worked well about 6 years. Now, The freezer is working well and the refrigerator is not working at all. Any suggestions where to start? Cpuld this be just a thermostat issue?
  • drvpod Jul 18, 2009
    It was indeed the fan, which had simply fallen out of position.
    Thank you!!
  • Kenmore Master
  • 1,606 Answers
Sounds like a freezer fan problem . Not a thermostat problem . Could also be a defrost problem , if so , then look for frost on the rear wall of the freezer inside to determine .
Posted on Jul 17, 2009
I have a Kenmore refrigerator 795690002900 bottom freezer. The freezer is working but the fridge doesn`t work. The temp adjustment for freezer lits up the 6 and 7 will not adjust, the fridge part does not...
Mine bottom freezer 10 or so year old unit did the same thing, problem was the thermal switch ("clicks on") on de-ice circuit was broken. Quick "fix" is to defrost the unit by shutting it off, putting frozen food in a cooler. Once the ice melts the path for blowing cold air UP to the frige will be opened. Will work fine for days until the freezer ices up again.
Most likely the "clicks on" or thermal swithch that is bad and will not let the defroster heater work. Easy fix. Everything is BEHIND the pull out frozen food tray. Remove a couple of screws and you will see all the ice. If I remember correctly my clicks on was just to the right of center and took only 5 minutes to replace after defrosting the unit.
Hope this helped,
Ken C
Apr 30, 2012 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
A 10 year old kenmore bottom freezer will not freeze ice-cream
have a taken off the kick plate at the bottom of the unit and cleaned the dust,it is something that should be done at least 2 timesa year
Jul 18, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Temperature is not cold enough?
Model #106.8678213, The complaint was the refrigerator section was getting warm while the freezer seemed OK. The unit had been unplugged for a couple days and when I turned the unit back on, the cooling system worked fine, but I did notice a lot of water in the condensate tray which lead me to a possible defrost problem. Removed the access panel to the defrost timer and found the timer motor was not running. So basically what happened was the unit stopped defrosting and eventually built up enough frost and ice on the evaporator to block the airflow to the refrigerator section. Once the power was removed, the unit defrosted by itself and left the water in the tray. I replaced the defrost timer so now it will defrost every 8 hours like it was designed to. Now get back with me and see if the model number located on bottom kick plate it should be a number that Sears only uses. They use model numbers like this on everything and every brand. looks again like this sample ( 106.8678213 ) hope this helps, Sea Breeze
Apr 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite bottom freezer refrigerator...water won't work
I turned up the temperature in the freezer and the refrigerator. The next day the water was flowing.
Thanks for your time.
Sherry Piper
Jan 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking out freezer door--unit is still making ice
There is a shroud at the back of the freeezer. (Mine was a GE) but under the shroud is the evaporator coils and also a heating element to defrost the coils during the defrost cycles. Mine had the gutter underneath misaligned and the water went into the freezer and froze instead of going down the drain. I thought it was a ice maker leak until we found that. The weird thing is we had the refrigerator for about 6 years before it started leaking like that.
It has worked fine for about a year since that "fix"
Jan 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
269 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
