Question about Mitsubishi WD-65833 65" HDTV
Mitsubishi TV 2001 WS-55807/55" quick t power itse/ off ... $800?
Greetings, Thanks to this site, I pushed "Menu&Input" and got the code 1-2. A repair shop said if does in fact turn out to be lamps, what the code suggests, it would be about $600-800 to repair. Is that a realistic price? Any guidance before the repair would be appreciated.
  • imagin8er Jul 17, 2009
    Symptoms are TV screen not lighting up.  When attempting to turn on, I hear the TV's normal "click" and the normal green light under Timer for two seconds only, then nothing.  Repair scheduled for 1pm later today, but I'd rather pay you, Skyassoc!
  • 668 Answers
The Code 1-2 actually tells you that there has been no error detected according to the service manual. What are the exact symptoms?
Skyassoc.
Posted on Jul 17, 2009
  • Steve Yocum Jul 17, 2009
    There is a good chance that you have one or two open pico fuses on the Power/Convergence Board. These fail when the Convergence circuit fails. If this is the case, it will need two STK392-570's or a STK393-110 depending on the exact Convergence circuit design. Probably the STK392-570's.
    Once the repair is done and done properly, you should be good
    for a couple of years for that problem anyway. Cost wise I would estimate 250.00 to 350.00 depending on the cost of the service call fee.
    I hope it works out well for you,
    Skyassoc
Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
Sep 25, 2011 | Mitsubishi WS-55815 TV
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi VS-70707 rear projection TV
Try pushing Input and Menu together and hold them both in for 5 seconds to see if it blinks a 2 digit code which repeats itself. Then let me know what it does and we can go from there.
Jan 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Geometry - Edges cut off
1)power on TV
2)Push menu-1-2-5-9 in quick succession
3)Use 4-5-6- to change colors
4)Use enter to blink / unblink cursor ( blink = move, unblink =
adjust )
5)Finished? = menu out to save changes
Please rate this solution......................................
Nov 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
357 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
