Our 2 door ref, Electrolux, turned not functioning though we can hear its motor running but sounding not the ussual sound as normal.It happened before and what we did was pulled the plug out and after 24 hours we plug it again and it then functioning, but this 2nd time its not doing the sme thing and even the bulb not turn to light up. What seems to be the problem? Thank you.
SOURCE: U-Line 15WCSS (wine refridgerator) not working.
most likely the thermostat is bad not bringing the unit back on. the thermostat is the temperature control knob located in the toe grille of the unit. on the u-line unit replacing the control can get kind of involved but if you will follow the directions supplied with the part yyou can do it your self.
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
SOURCE: GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
SOURCE: The fridge section of my Miele fridge/freezer
HI
Most likely problem is NTC, which is behind cover at rear of light.You will require torx screwdriver to remove. It's the one with green markings on screwed to the back wall of the fridge. Part no.7323301 it about 35 pounds to buy
