Question about DISH Network IR Remote Control
Dish network remaote all lights are going on at top of remote and staying lit. Than all will shut off. Remate does not function. Thank you
I just had Dish installed and 1 remote would not work at times on a dual receiver. It was only at night when we had the lights on. We had 2 lights with Compact fluorescents. One was a round tube and one was a 3 way. Last night I was trying to set up to record and nothing worked. I was ready to scream. I said to my husband I am going to go program it from the other TV in the other room and turned off the one light and all of a sudden it worked. Turned the light back on and then it did not work.
Posted on Aug 27, 2009
  • 374 Answers
You need a new remote as yours is defective. Thanks for using Fix Ya.
Posted on Aug 16, 2009
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Nov 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
Dec 30, 2012 | DISH Network IR Remote Control
My dish network remote isnt working with my Sony Bravia LCD model KDL-40S5100
You didn't mention the model of the Dish receiver, so here are some common Sony codes. To reprogram the remote, press and hold the "TV" button on the remote until it stays lit. Enter one of the following codes and press "#". Check all of the functions. 500,640,652,756,758,781,783,795,796,797,798,806,807,837,844,845.
Apr 19, 2011 | Televison & Video
I have dish network setup, and vizio 42" HDTV. The Dish network remote is already able to control the TV power and sound options, however, I want to control the TV Setup options too (specifically the...
Hello, my name is Becki Barned, with Dish Network customer service. To get your tv to work those particular functions, you will need to reprogram the remote to the tv, finding a code that works all functions of the tv. Some codes will work the power and volume, but not the other functions. Try these steps:
1. Hold down the TV mode button until all lights at the top of the remote are lit up
2. Press the 3 digit code in
3. Press the pound button
4. Press the SAT button on the top left of the remote.
Here are the codes to try:
505
671
627
864
006
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
I can not progam my disk network remote to control my new Auria tv. i can use most functions except to on/off and volume
Hi, this is Cheri Torres with DISH Network customer service.I came across your question and wanted to see if i could help. :) I was lookingthrough all of our remote codes for all of our IR remotes and I didn't see anycodes for Auria TVs. An option you can try instead of using remote codes is a channelscan. A channel scan will basically go through all of the possible codes wehave and find the correct one for your particular remote and TV. Whendoing a channel scan you will first have to press and hold down the TV buttonon your DISH remote until all the mode lights at the top of the remote light upred. As soon as all the lights are lit, let go of the TV button, press 500, andthen the # (pound) button that is located under the number nine. After thisprocess is done you will press and hold down the TV button again until all themode lights are lit. Then you will press the big red power button once andrelease, next press the up arrow button once every second. You will keeppressing the up arrow until you see your TV turn off, as soon as the TV turnsoff you will press the # (pound) button right away. Once you have completed allthese steps you can try all your TV functions to make sure it is workingcorrectly. I hope you find these instructions useful. If you have anyfurther questions or concerns feel free to post back here or email me atCheri.Torres@Dishnetwork.com.
Dec 29, 2010 | DISH Network IR Remote Control
Dish remote TV red light stays on and remote not functioning at all
Hello my name is Mayra Diaz with DISH Network. I apologize about your remote control not working properly it will be my pleasure on helping you with this issue. When the red light stays on it normally means that the remote control needs to be replaced. If you are still having this issue please post back and it will be my pleasure to look into this further to get the issue resolved for you as soon as possible.
Sep 23, 2010 | DISH Network IR Remote Control
SAT light stays lit but no functionality.new batts, still nothing. reset DVR, still nothing
beavs72,
If the Sat button stays lite with no function to control the receiver, either the Sat button is stuck or the remote has gone bad, especially if you already changed the batteries. You can call 1-800-333-3474, speak with Tech Support and if needed, they can send a new remote. I hope this helps.
Ray Calo
DISH Network
May 11, 2010 | DISH Network 721 DVR Remote Control
Remote control code for dish network controler.sat.box vip211k
It would be our pleasure to help you with getting your DISH Network remote to control your Insignia TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your TV; here are some of the codes we currently have: 834, 538, 720, 000, 834, and 697. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Insignia TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 13, 2010 | Insignia IS-LCDTV32 32 in. Television
Need the codes to program my dish network remote ???
We're happy to help you with getting your DISH Network remote addressed to your TV. We're going to start by pressing and holding the TV button on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have: 505, 598, 627, 520, and 627. Press the pound (#) button to save the code in your remote. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Vizio TV until you find one that is compatible with it.
Phillip Chang
Feb 05, 2010 | Vizio L32 32 in. LCD HDTV
Sat button on remote stays lit and it won't let me do anything in just stays lit. I have even changed the batteries
jsblondie316
If the light stays on and you have already replaced the batteries, then the remote needs to be replaced. Please call 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Jan 14, 2010 | DISH Network 142923 Remote Control
DISH Network IR Remote Control Logo
164 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
