Question about Sport & Outdoor - Others
How do I replace my broken cabel in my '94 Skamper pop up camper?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Goshen has blueprints you can download for free and very good prices on their stamping parts :-)
Posted on Feb 25, 2015
Answer can be found on manufacture's web site for the lift system
http://www.goshenstamping.com/lift.php
good luck... It worked for me.
Earl Niles. Eeniles@gmail.com
Posted on Dec 16, 2014
How do I replace my broken cabel or coil in my '94 Skamper pop up camper. The cabel is bent on the right rear corner, It is twested and bent and I have tried to repair it but keeps getting twested and re-bent. My question is if I can't replace it or repair it can I cut it off andraise three corners and left the right corner and prop it up with a bar support.
Posted on Sep 08, 2009
Have no spark, have replaced crank angle sensor, im told the ecm is ok,new coil, new ignition module, new rotor, can someone help me please 93 Jaguar xj40 4l
what about the distributor cap?? do you have a spark from the centre lead that comes from the coil??These vehicles also have a factory immobilisor ------ do you have power to one side of the coil??i have a 94 sovereign 4lt as well and a workshop manual somewhere ?? looks like i will have to dig it out
Oct 24, 2009 | Jaguar XJ Cars & Trucks
Broken Cable on Pop-up trailer need help
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Sep 06, 2009 | Sport & Outdoor - Others
Rockwood pop-up camper.when i try to use hand crank to put it up or down only the back seems to go up not the front
Hello.
You either have a broken cable, or it may have come loose. Gain access to your anchor points and check the cables. Replacement cable can be purchased "by the foot" al Lowe's/similar as well as cable nuts and such Check the axels and spools powered by the hand crank for anything out of whack, like a broken weld on a cable drum, etc.
Best regards, W/D
Aug 17, 2009 | Coleman Campers Grill
I am looking at a 94 Coleman pop up camper. The
They are a closed system, so obviously it had/has a leak. You can get some AC guys that will retrofit it to allow for adding freon, but if it has a leak anyway, which will probably cost you a couple of hundred bucks to find out you have a leak that may not be evident until after you've already bought it, then leaks out again, and your back at square one. Depending on what size BTU's you want, you can pay anywhere from $500-$1000 + plus inside controls etc, if needed.
Jul 10, 2009 | Heating & Cooling
Pop up Camper will not raise up when cranked
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
Jun 04, 2009 | Arc'Teryx Rock & Ice Climbing
The air conditioner on my pop up camper is loud and vibrating
sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
May 31, 2009 | Coleman Campers Grill
84 Starcraft Stardust pop up camper repair/parts manual
I have a stardust camper which I converted to a utility trailer, what do you need, I can send you the manuals and paper work I have, the other stuff might not be worth the shipping?
May 11, 2009 | Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Broken cables to lift roof
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
This should help, Pictorial and instructions. Also parts available.
Thanks for using Fixya
Jerry
Mar 24, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
620 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
