Question about Abit AB9 Pro Motherboard
Not powering on, but active power supply - Abit AB9 Pro Motherboard
  • 922 Answers
1. Make sure you have all of the power connectors connected. There may be an additional 4-pin P4 connector and another on your video card.
2. Make sure CPU, RAM and cards are all well seated.
3. Frequently failing power supplies deliver less power before they die completely. It may just have enough power to spin the fan. Try another power supply. They are cheaper than a new MB and you can return it if it doesn't fix the problem.
I hope this helps.
Posted on Jul 17, 2009
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
Power Window System Controls
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
How do I get power
Older passive computer speakers do not need a power supply.
Modern active speakers might use batteries but mostly need a power supply that plugs into the mains power outlet and provides the right voltage, current and polarity the speakers need.
Some low-powered active speakers simply plug into the computer usb.
Oct 05, 2015 | Audio Players & Recorders
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
System health is critical. Red light flashing and system won't coming on
There is a critical system component hardware failure of some kind.
Front panel indicators:
1System power LEDGreen = Power on2Health LEDGreen = Normal3Power cap LEDGreen = Power cap configured4NIC 1 activity LEDGreen = Network link 5NIC 2 activity LEDGreen = Network link 6UID LEDBlue = Activated
Rear panel indicators:
1Power supply 2 LEDGreen = Power supply is on and functioning2UID LEDBlue = Activated3Power supply 1 LEDGreen = Power supply is on and functioning4iLO 2 link LEDGreen = Linked to network5iLO 2 activity LEDGreen or flashing = Network activity6NIC 2 link LEDGreen = Linked to network7NIC 2 activity LEDGreen or flashing = Network activity8NIC 1 link LEDGreen = Linked to network9NIC 1 activity LEDGreen or flashing = Network activity
Sep 09, 2013 | HP ProLiant ML370 G6 Server
When I press the power button to turn it on, it lights up green momentarily, then turns off again, and won't power up.
Please check the power supply unit. it is possible that the power output is less and so cut off when the power is activated.
Also it is possible there are errors in the main board and so when the CPU activates the power supply it encounters a SHORT and so cut off as a protection. if so remove main board and connectors to check by disconnection of circuits.
Mar 29, 2011 | Office Equipment & Supplies
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
PC start up failer
  1. remove the two rear screws and remove all the cards attached to the main board
  2. unplug all the cables that connect from the drives to the board.
  3. power on the unit
  4. if the unit powers up, install one of the cards you removed and complete step 3
  5. if the system does not power up, the last card or device activated will be your culprit and will need to be replaced or left out.
if you find that your system will not show a bios splash screen with all the other components removed, then you are looking at either a video, or power supply failure. Listen to your system for spinning fans and hdd activity. touch the hdd if you cant hear it when you power up the system, paying close attention to when the drive activates. It should activate almost immediatley, pause, and then run for a short boot period. if nothing, then if may be your power supply. you will not be able to see any lights at all, no light on the motherboard, drives, or power LED is the best indicator of a shot power supply
Good luck, please rate this post
Mar 23, 2010 | Acer Aspire E500 PC Desktop
My ups cannot give backup when AC power fails no power supplied to PC then PC is restarted but i replaced a new battery but no result found. What is the solution for this problem ?
It sounds like you have a computer with an Active PFC (Power Factor Correction) Power Supply.
Back-UPS units, when running on battery power, output a Modulated / Stepped Sign Wave. Active PFC Power Supplies are NOT compatible with this pseudo-sign wave power, which is the reason it will not stay running.
You need a Smart-UPS unit, capable of delivering a true sign wave when on battery output.
Feb 13, 2010 | APC Back-UPS 400VA (BK400) UPS System
Abit AB9 Pro Motherboard Logo
159 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
