56HM195 DLP has purple/blue streaks that start from left to right by icons or shadows. The color is ok but image is slighly blurred also.
  • 1 more comment
  • danduckworth Jul 17, 2009
    I took the bulb out it was not burned, looked good. Cleaned inside TV bulb area and blew canned air on the half dollar size window. Re-installed bulb then turned TV on and still had blue/purple streaks.
    I guess it must be the light engine. What do you recommend just buying another TV or repairing this one? And if I purchase another TV is the old one worth anything? Also is it possible for me to order a light engine and install it myself or is it very difficult to install requiring specialized equipment?
    My 56HM195 Toshiba DLP TV has blue/purple streaks going from left to right across the screen. Seems to appear in shadow areas but sometimes all the way across the screen. Also the picture is a little fuzzy but color is ok.
  • danduckworth Jul 19, 2009
    I have a Toshiba 56"DLP TV. Model 56HM195
    The problem is blue/purple streaks filling the bottom of the screen working it's way up to about 3/4 of screen. They also appear as blue/purple elongated shadows running from edge of objects left of screen to right.
  • 11,896 Answers
Either the color wheel will most likely have to be replaced. Take a closer look to see if the purple coloring is any different then the rest. If colors are bad, change it, if the colors and wheel look ok, then it's time to test the capactiors and the ballast with a multi-tester.
Posted on Jul 19, 2009
    President:
  • 512 Answers
It seems there is a convergence problem. The complex convergence circuitry is failing. It is not something you can fix unless you or someone in the house is skilled at soldering and has some electronics experience. Should be fixed by a trained tech.
For the heck of it try a hard reset first to make sure it is not a corrupted software code. Unplug the power cord for 5 hours then plug back in and power is up. This sometimes works, if it doesnt then it need to be repaired.
Posted on Jul 17, 2009
  • 441 Answers
This is one of two things, a problem with the optical engine witch would be a 500-600 repair, or the second option and more likely is you have a bulb problem. First unplugg it for a hour and try again (I know it sounds stupid but just try) Then remove the bulb and dont touch the glass, if it looks burnt than the bulb it going, time to replace it. you can order a repacment online at lamp-dlp.com It would also be a good idea to blow out the dust in the bulb chamber with air. Good Luck
  • John Riley Jul 17, 2009
    You could do it yourself if your very good with electronics, When mine went out I just bought a new set. The parts cost almost $900. You might be able to sell you old set on ebay for a little to help offset the cost
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Stereo wiring color code for a 94 dodge shadow
1994 Dodge Shadow Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5? x 7?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
Nov 14, 2010 | Dodge Shadow Cars & Trucks
I can not find out the color meanings. Power, ground and such please help!
Ok,
Power 12V + : Yellow
Ignition Switch : Red
Amp Turn on : Blue / White stripe
Antenna : Blue
Ground : Black
Illumination :Orange/White
Dimmer : Orange
Left Front Spk + : White
Left Front Spk - : White/Blk
Right Front Spk + : Gray
Right Front Spk - : Gray/Blk
Rear Left Spk + : Green
Rear Left Spk - : Green/Blk
Rear Right Spk + : Purple
Rear Right Spk - : Purple/Blk
Hope this is helped you,
Good luck.
May 21, 2010 | Pioneer AVIC-N1 Car DVD Player
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Televison & Video Logo
506 people viewed this question
Top Televison & Video Experts
Electro Med Services...
