The monitor switch is likely causing the fuse to blow because one of the other switches is stuck in the closed position. If this is the case, replace both the monitor switch and the defective switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Testimonial: "Thanks, yes the light comes on for a second then fuse blows. I'll replace it, thanks!"
