Question about Saeco Magic De Luxe Espresso Machine
The water that is pumped thru the grounds is too hot producing a burnt flavour to the coffe
  • 2,039 Answers
The thermostat on the pump is defective need to be change
Posted on Jul 31, 2009
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
What is instant coffee?
Instant coffee is basically ground coffee that has been freeze-dried, packaged and sold. It is rehydrated by pouring hot water over top. This type of coffee is ideal for travelers or to anyone without a coffee pot/time to wait for their coffee to brew.
Feb 07, 2013 | Wine & Spirits
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
OIL PUMP WORKS WHEN IT IS COLD. WHEN IT GETS HOT AND YOU'R AT IDLE THE OIL PREASURE DROPS TO NOTHING.WHEN YOU SPEED BACK UP,THE OIL PREASURE GOES BACK UP?
the oil pump is working when it,s hot too you just don,t see the results because the oil is now hot and thinner once engine comes up to operating temp. the tolerances on the main and rod bearings are so large that the pump cannot produce pressure have you ever tried to wash car with just water hose does not work well you put your finger over the end of hose create a restriction and now you have pressure water sprays out hard well when all bearing surfaces are in good shape and bearing clearences are in spec. it is a very tight fit that the pump has to pump oil out of pan thru oil galleries and to and thru bearings this produces pressure pull the oil pan mark it,s location remove one main bearing cap and one rod bearing cap plasti-gage and you will see your problem
Sep 20, 2010 | 1990 Ford F150
Water output too slow
Try to see how long takes whout coffee. If it is ok then the coffee is too fine or wed or the filter inside the holder need cleaning remove filter and wash it with hot water and brush so all holes to be open.
If after this you still have slow water without coffee the the pressure pump is not working properly and it need ither descaling or is complete damage so you need a new pump. Good luck.
Please remember to vote for this answer thanks
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Does not produce any output after I cleaned the water container, filled it and replaced. I let the machine warm up for about 5 minutes as usual, and then tried to make coffee as usual. I've had this...
Sounds like there is either an airlock or the pump is not working. Try running the hot water cycle to prime the pump, if you cannot hear the pump going then it will need to be replaced.
Jan 25, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Coffee maker brews too hot
The 1-4 setting makes the coffee extremely hot. If the 1-4 setting was not activated, make sure you are not using paper and permanent filters at the same time. If you are not using them at the same time, it is time to clean the coffee maker out with 2 cups vinegar and two cups water.
-Tha Mp3 doctor
Nov 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Saeco Magic De Luxe Espresso Machine Logo
56 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
