Question about Philips 50PFP5332D 50 in. Plasma Television
We own a Philips 50PFP5332D/37 that will not power up
When you try to power up the unit, it just makes a clicking noise and will not power up. We took it to a local repair shop, and was told we need a new power supply that would run $425.00. This seems like an expensive fix. Of course the TV is no longer under warranty, the warranty expired in May!! Help! Thanks!
  • Emma1107 Jul 24, 2009
    Thank you for your suggestions! We found a TV repair man that was alot less than $425, and he changed out the capacitors for us, as we did not feel comfortable trying to attempt this ourselves. Thanks again!!
  • 10 Answers
I have the same tv with the identical issue. I replaced the capacitors that were bad on the power supply board. You have to be comfortable taking the tv backing off and removing the power supply board which is located in the top middle if you take the back metal cover off. Once off, look at the capacitors on the right side of the board, you should see black goo on top of them. Those are the bad ones that need to be replaced. Maybe you have someone you know who can fix that for you or you can simply order a new power supply board online for about $130 and replace the whole thing yourself. either way, it's cheaper than the shop. Some power supply boards are much more expensive than others, so make sure you have the right part number. Best of Luck and be very careful of you try this yourself. There is high voltage on this board so only touch from the outside of the board. Again, have an expert do this if you are not very comfortable doing it.
Posted on Jul 21, 2009
  • dustynnelson Jul 22, 2009
    Since you have the idental TV that I do, I replaced 4 caps rated at 680 mfd at 50v and 1 1000 mfd at 16 v. All caps were ordered at Digikey.com. Look under Aluminum Capacitors and select the correct microferrit (mfd) and voltate (v). You might have just the 4 blown. I replaced mine with the 10000 hr caps so I don't have to worry about this issue for a long time again. Let me know how you did.
    Sergeant:
    Champion:
  • 227 Answers
If you are in Maryland take it to DVT REPAIR CENTER they will fix it for way less than that. you can call them at 443-449-4559.
Posted on Jul 17, 2009
I can fix your tv only $150
Posted on Aug 14, 2012
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips tv model number 50PFP5332D 37 wont power up
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a philips model 50pfp5332d 37 We turned it on and it just clicks (like it is turning off an on) no picture, nothing. Will not respond to the remote or to the on off switch. Had to unplug to stop...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Philips 50PFP5332D 50 in. Plasma...
My Philips flat screen tv model 50pfp5332d/37 I turned my tv on the blue light is on but nothing is on the screen it's making a clicking sound
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Nov 03, 2010 | Philips 50PFP5332D 50 in. Plasma...
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
I have a phillips 50 inch plasma- model 50PFP5332D/37- when its plugged in it makes a clicking noise and the light is on indicating it is on, but picture never comes on- help
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
Oct 23, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PFP5332D 50 in. Plasma Television Logo
1,886 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
