Canon MF-6550 ''toner not set''
Could someone tell what's wrong with the machine when you install 2 new toner cartridges in and it kept saying ''toner not set'' but when put the old rebuilt cartridge then it work fine. I did hard (unplug everything overnight) and soft reset but still the same thing. Greatly appreciated.
  • apex298 Jul 17, 2009
    I checked everything, compared between the brand new cartridges and the rebuilt one, nothing different at all.
    President:
  • 828 Answers
Check properly to toner if there is some stickers left on it and put it tightly to recognize it...
Posted on Jul 17, 2009
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon IC 6530 After installing new toner cart, machine is still saying toner is low
maybe the cartridge you are using is a refurb. and the sensor is not working or the chip is bad.
Mar 30, 2009 | Canon MF-6530RF Factory Reconditioned...
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon mf 6550 copy no print out its came out empty page
We had the same problem with our mf6550 printing blank pages after we changed the toner cartridge. I called the support desk today and they said it is the shutter. They told me to remove the toner cartridge and then (without a cartridge in) close the door briskly. Then open the door, install the cartridge and again close the door briskly. It worked! He said it may be a permanent fix or it may act up again. He also said I could take it to a service center to have it fixed permanently. The service desk # is 1-800-828-4040. They can tell you where the nearest service center is. Good luck.
May 05, 2008 | Canon imageCLASS® MF6550 Laser Printer
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Toner not set
"Take out the paper from the machine and the toner cart unplug the power cord for 10 seconds then plug it back in that will fix it"
This solution worked for me but actually unplug the machine not just turn it off.
Jul 17, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
293 people viewed this question
k24674
jasbo
jasbo
