Question about Palm LifeDrive Handheld
It wont power on how do i get the palmone lifedrive to come on it dont even come on even when begin charged
  • 1,606 Answers
Usually those symptoms mean a motherboard problem or a battery problem. Both are replaceable and worth doing if you use your LD.
You can try a power reset. Plug the LD in and hold the 5 way button down then reset the Ld using the reset button. You may need 3 hands to do this. Sometimes this will reset the power section and get you running.
Posted on Jul 30, 2009
Lifedrive won't start. Neither will it reset,
Unfortunetly that usually indicates the harddrive has failed on you. Try a power on hard reset. It is the same as the hard reset but the power need to be plugged in as well.
If you look there are several places that will replace the drive with either a new drive of a compact flash card. The card is the way to go as it increases battery life but is about 10x faster acessing stuff.
Dec 13, 2009 | Palm LifeDrive Mobile Manager Handheld
My palm doesn't seem to be charging at all. The
The clicking noise usually indicates a hard drive problem. There are replacements available. You can get a replacement hard drive or a flash card drive. Of the two the flash drive is by far the better choice.
Nov 06, 2009 | Palm LifeDrive Mobile Manager Handheld
Lifedrive wifi
Does the wifi work at all after it resets? Have you applied the level 2 palm srvice pack to the LD? I believe the update changes how the wifi operates. If you go to www.palmone.com and go to the lifedrive page you should see a list of downloads for it. If you click on the 2.0 update there is a description of how to tell if you need this or if it is already installed. You just need to check the version of one file. Download and install the patch and see if that fixes everythng.
If that doesn't fix it you may have a more serious problem that could require replaceing or fixing the LD
Oct 27, 2008 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead LifeDrive
I would guess you bought a dud micro drive or its been cleaned off. You could try a hard reset and see if it fixes itself. Perhaps the fellow cleaned off his information but hopefully he left the restore partition alone. You can rebuild that if you extract the files from the 2.0 upgrade and so on. There are a few tutorials on how and what to do on some of the hardcore LD sites.
Hopefully you didn't harm the board itself with a static discharge. I've seen a few guys do the swap and end up with a dead LD but usually they don't see anything at all.
May 22, 2007 | Palm LifeDrive Mobile Manager Handheld
BackupBuddy VFS Pro supports the LifeDrive?
The readme info needs to be updated. The current readme is actually from the previous version and out of date. It should now look something like this.. (note newest info at top, previous version info underneath) BBVFS 3.1.4 New features include: + added option to backup after HotSync + LifeDrive compatibility fixes Bug fixes include: - some password letters were being ignored - fixed problem of backing up files encrypted with the built-in Security app - blank screen/crash on startup - crashes during orphans processing - no scrollbar appeared when there were more than 10 checkpoints in the list - didn't fail gracefully when trying to restore corrupted backup files BBVFS 3.1, 6.05 * Users may now select which card to backup to on devices with more than one card slot * Backup and Restore of T5 internal drive (!) is now supported * Backup of databases with records > 64K is supported, which will allow backup/restore of Photo/Videos on T3/T5/T650 and "VoiceDial" application * Advanced screen now adds new files to the backup set automatically * Wireless updating (via "About" screen) * Implemented a Palm Source Installer package * Many important bug fixes, including: Several issues relating to compression and encryption "Last Backup" being incorrectly set to "NEVER" No longer will soft-reset if no card is mounted on the T5 TUNGSTEN T5 SUPPORT This build includes further refinements to backup and restore on the T5 but we have confirmed with PalmOne that there are some issues with the T5 NVFS implementation that require a patch from to completely resolve. We recommend that all users download and install the T5 patch that is available here: http://www.palmone.com/us/support/d...ent5update.html Alternatively T5 users may want to try a program called "DBCache Tool" which you may download here: http://www.jade.dti.ne.jp/~imazeki/palm/DBcT/ LIFEDRIVE SUPPORT We are aware that this release contains some remaining issues with the new PalmOne LifeDrive and we are working to resolve them. Please contact support@bluenomad.com if you'd like to help with testing. BBVFS 3.07, 1.05 BackupBuddyVFS 3.07 is being released with preliminary support for the T5/Treo 650, although there are still some outstanding issues that we are continuing to investigate; specifically: * Power Users with a (near) full device especially may experience "out of memory" errors and/or random resets; restarting the backup or restore operation will usually allow it to reach completion. This is due to issues with the new "NVFS" file system on these new devices that developers cannot currently work around. We hope that palmOne will issue a patch to fix this, and we will continue to try and find a work-around. * Photos and Videos will not be backed up on the Treo 650/Tungsten T5.
Sep 15, 2005 | Palm LifeDrive Handheld
PalmOne LifeDrive OS Installation
palm os is a flash rom built into the device, the only way your going to be able to do this (which will risk the device itself and i highly recommend NOT doing) is if you can get your hands on a flash tool to flash the ROM with your version of pocket pc os. i have never seen it done, but there are rumors that a palm treo 670 has windows mobile 2003SE on it. i just wouldnt recommend doing it because you could and probably will make your device useless and therefore will have to replace it. anyway, i strongly recommend that you not to do this unless you are really good with computers.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
palm os is a flash rom built into the device, the only way your going to be able to do this (which will risk the device itself and i highly recommend NOT doing) is if you can get your hands on a flash tool to flash the ROM with your version of pocket pc os. i have never seen it done, but there are rumors that a palm treo 670 has windows mobile 2003SE on it. i just wouldnt recommend doing it because you could and probably will make your device useless and therefore will have to replace it. anyway, i strongly recommend you to not do this unless you are really good with computers
Lifedrive calendar - private items
Fix in Outlook?? Isn't there a way to keep private appts from showing in Outlook? Perhaps you could change the setting on that side? Did you have trouble getting your LifeDrive to sync w/Calendar in the first place? I've managed to get all BUT calendar syncing (and it's the MOST IMPORTANT part of Outlook that needs to sync!!)... any advice?
Sep 12, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
341 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
