Question about Envision EN-985e Monitor
How do I replace my Intel Graphics Driver?
Dear Tech Support
My monitor keeps blinking on and off, every few seconds now, but the power lights stay on. I don't think the monitor is the problem. I think I need a new driver. I have been having problems for about 4 months now.I have received various messages that say "My computer has suffered a serious problem, etc. Messages such as"Intel Graphics Driver has stopped working properly." I don't think this is something I can do myself. Who do I call and where do I go to get a new driver? or do I need a new computer. It's about 4-5 years old. It must have blinked 30 times while I am writing this email.
Ann K.
  • 3 Answers
1. anti virus software
2. intel.com for driver
3. replace pc asap, it's kinda old
Posted on Jul 17, 2009
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Monitor just went dim.
The blinking power button indicates a short in the power supply which is then not putting out the full voltage needed to give a bright display. This is a very common problem with LCD monitors after 2-3 years of service. It is caused by heat buildup in the case causing parts called capacitors to blown out causing the power supply to short out which in turn make the power light just blink. You can repair it yourself if you can solder. We have a repair diagram posted on our web site at: www.ccl-la.com Replace the parts shown and you will be back up and running. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Let us know if you have any other questions about the unit or the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
May 30, 2009 | Acer X193W LCD Monitor
Monitor screen picture won't stay on for longer than a second
I had the same problem with my eMachine t3418. Site advisor Micromend suggested changing the power supply to more wattage. Very much recommend doing that. I did but it didn't fix the problem. Micromend also advised trying a video card. I bought a cheap vid card and installed it. It worked. Apparently MY problem was in the motherboard and the vid card worked around that. Much cheaper than replacing the computer. I'm NOT a tech. Just sharing my experience with what worked for me. I you have a laptop or a friend does, hook your monitor to it to test that it's okay first though.
Mar 18, 2009 | E-Machines eMachines Monitor E15T4
Monitor stays black
best guess is the monitor is bad. Try replacing the monitor first.
Dec 02, 2008 | E-Machines eMachines Desktop PC
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Jun 12, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
No interaction with the Monitor
Do you see anything at all after boot up or does it stay dead Check all the connectors. Check the driver situation. Check graphics card seating if this is a card aopposed of integrated graphics for this machine. Run the recovery disk Go to Dell Tech support.
May 15, 2007 | Dell E153FP 15" LCD Monitor
Computers & Internet Logo
79 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
