Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
  • 1 more comment
  • yardpros Jul 17, 2009
    oil level is fine, im leaning towards a vacuum problem or maybe a valve
  • waughjr May 11, 2010
    is the engine oil way over full? had that prob on one if it is its likely gas and leaking through carb.
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Posted on Aug 14, 2009
    Problem Solver:
  • 8 Answers
Is the tank itself clean? Gas can contamination, paint chips, etc., can plug the tank fuel outlet. This engine has a fuel pump too, does it not? Believe if so, it runs off engine vacuum. Check that system. What do the spark plugs look like? They can look good, yet be failed too.
A few other "simple" thoughts.
Good luck
Posted on Jul 17, 2009
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Jul 09, 2009 | Garden
My briggs & stratton will not start
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Ed
Apr 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,759 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
