Question about Motorola Mobility C290 Cellular Phone
Bootloader usb ini
My phone turned off on me when i was on the web when i turned it back on it said bootloader usb ini....what can i do about this problem? are they any solution that i can fix it for myself....please help thank you....
Re: Bootloader usb ini
I had the same problem so I called Motorola Tech support. They told me the BOOTLOADER USB INI message meant that the software for the phone wasnt updated and in order to update it to the right software you'd have to send it in to them to fix it for free ONLY if its still under their 1 year warranty or else you'll have to buy a new phone. So next time you guys get a new phone make SURE you UPDATE YOUR SOFTWARE REGULARLY! I learned my lesson. I am so pissed.
P.S. Is there anyway of getting your contacts off through the comp even if your phone wont power on?
Posted on Nov 25, 2008
0 characters
3 Points
Bootloader usb init
hold the end key(power) and it should restart back to normal. If it goes back into bootloader then your phones software could be corrupt or could have a wrong value in somewhere. What provider is this?
Jul 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader USB INI
It sounds like to tried to hack the phone,,never heard of bootloader
showing up unless you tried to load it, you probably can't fix this unless you know how to look at the firmware that runs your phone.
Best thing is too take it too your carrier store that has a repair
on hand or sent it to moto, if you tried to hack they will charge you
for messing with it, if you did not then it should be free,,should be,,
Also wait and see if you get a better answer,,,I have only hacked
all razors Iphone, lg vu, never touched the phone you have.
Dec 30, 2008 | Motorola Mobility ic502 Cellular Phone
Bootloader USB INIT
Get this Phone reflashed. Of course if you Dropped the Phone or if it went into water then Forget it about spending 35-50 Bucks on reflasing this phone. because it will go back to Boot Mode.
Sep 06, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Bootloader USB INIT
Reflashing the phone requires that you have acces to some service software programs (PST for example) and a correct, unlocked, stock flash+flex pack, also compatible with your bootloader version. As a general rule of thumb, if you don't know what this terms mean i recomand you try to avoid the process. Some people ended up with bricked (dead) phones because they simply didn't had some field experience with flashing phones or service and bootloader commands. My advice would be to play it safe and try to get help from a service center.
Jun 19, 2008 | Motorola Mobility C290 Cellular Phone
C290 - Bootloader message
You need to flash it. Need a USB cable, RSD lite soft and the flash files.
May 12, 2008 | Motorola Mobility C290 Cellular Phone
What does bootloader usb ini mean
no one can help you with this issue ..if you call the motorola help line for cell phone repairs they tell you they have to flash the phone and you will get the phone back in two weeks time.this is thier phone number 800-331-6456
Apr 28, 2008 | Motorola Mobility C290 Cellular Phone
Bootloader usb ini
I' take it to a telstra shop and ask them or if they can't help take it to a repairer
Apr 02, 2008 | Motorola Mobility C290 Cellular Phone
Blue screen Bootloader usb init turned my phone off and now it says bootloader usb init?
Goto google and look up Bootloader USB ini you will get results from Howards Forum telling you on how to reflash your phone follow the instructions.. Ignore the post about "V3M bricked but not hopeless" thats mine and its a different situation from yours. Good luck!
Mar 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader usb ini
take the phone to a mobile service center and have them reflash the firmware on the bring it back.
Jan 26, 2008 | Motorola Mobility RAZR V3
Motorola Mobility C290 Cellular Phone Logo
758 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
