Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
1991 90hp Force. charging at 16.5 - 17 volts when
1991 90hp Force. charging at 16.5 - 17 volts when running full out. Is this normal. Engine has a rectifier but not a regulator. Thanks
  • 86 Answers
Very normal. That is what is gonna charge the battery. At idle it should run at 13 to 14 volts. Definatly a healthy sign man!
Posted on Aug 06, 2009
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
Aug 16, 2015 | 2001 Ford Expedition
What amperage should my
It all depends, most bikes have a low amp rate for charging around the 1 to 1.5 A mark. What you need to check is the voltage across the battery with the engine running. The normal voltage across a battery is 12.5 to 13 volts. With the engine running you should see about 14.4 volts. Bike batteries like a low rate charge.
Sep 03, 2014 | 2009 kawasaki Vulcan 900 Classic LT
The battery is not charging in riding time . Battery new fitted after 300 kms Battery become dead what is the solution for this problem ?
Check the charging voltage at the battery with the engine running, it should be about 14 volts if you have a 12 volt system or 7 if you have a 6 volt system. The voltage should be about 20% above the normal battery voltage with the engine running at about twice the idle speed, to charge it.
Feb 11, 2013 | 2006 Hero Honda Splendor+
How many amps on amp meter 1995 jeep cherokee
I think you are looking at the voltmeter, not the ammeter.
11 volts means the alternator is not charging if the engine is running. There are some conditions that exist in normal operation where the voltmeter can register 11 volts and it not be an issue, but if you are driving down the road, and only have 11 volts- the vehicle is running off the battery to keep the engine functioning for only a few miles more.
An ammeter in a car or truck has to be able to handle the full output of the alternator- which can range from 35 amps for some, up to 165 amps for others and higher. It is this reason ammeters in motor vehicles rarely have any numbers on them, just plus or minus sign, or the words charge discharge.
Feb 07, 2012 | 1995 Jeep Grand Cherokee
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Battery keeps dying,starts immedetily when you hook jumper cables to it,could this be the alternator?
it could well be that if its not charging the car battery up,,or it could be you have a dud battery that just wont hold its charge any more
Jul 04, 2010 | 2005 Chevrolet Colorado
My battery light and engine light came on while riding, what could be issue?
I would check the charging system on the bike. With the battery at full charge, start the bike and measure the voltage at the battery. Use a DVOM (digital volt ohm meter) and put the red probe on the positive terminal and the black probe on the negative terminal of the battery. Put the meter in DC volts 50 volt range. When you rev the engine a bit, you should read 14.5 - 15.0 volts. If you're reading under 13 volts with the engine running, your charging system had gone out.
May 22, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Battery only has 10.6 when full load
Only 10.6 when the engine is running? Have the alternator checked.
Apr 03, 2010 | 2006 Subaru B9 Tribeca
When I start my 2009 Chevy Silverado it shows 15 1/2 volts. Within a few minutes it goes to 12 1/2 volts. Is this normal?
This is normal, My '04 GMC, goes to around 16 at first start-up then drops to 131/2 after it runs a while.
Oct 31, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
223 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
