Lost red color on myh dlp led tv - Televison & Video
  • 304 Answers
You have either a bad LED Driver bd or a bad RED LED Chip. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
Lamp status flashing orangey red
Your lamp door switch isnt activated. either the door isnt secure or the wire isnt plugged in. Flashing orangy red LED means just that.
May 13, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
What is causing white vspots on my tv?
As you probably know, your DLP (Digital Light Processing) TV works by projecting Red, Blue and Green light from three LEDs or a color wheel depending on your model, onto the DLP chip which contains rows of thousands of tiny mirrors. These mirrors reflect the colored light through some lenses and other fixed mirrors and onto the back side of the big frosted plastic screen on the front of your TV cabinet. In the neutral position, these little mirrors don't reflect any light onto the back of the screen. If they flex into a certain position they will reflect any light from the three LEDS shining on them. What color depends on which LEDS are on at that moment. Each one of the mirrors is roughly equivalent to a pixel.
Any mechanical thing will eventually fail and if any of these mirrors fails in the OFF position, then no light will be projected to that mirror's target on the big screen. You are not likely to notice one "pixel" on your screen being dark though. However, if any of the mirrors fail stuck in the in the ON position they will continuously reflect all three LEDs light to that mirror's target on the big screen. This little white dot is noticeable and your attention will constantly be drawn to that stuck mirror's white spot. Once one mirror fails it is only a short time before more and more mirrors stick in the ON position and you see dozens then hundreds of white specs. It's VERY annoying.
Fortunately, if you are fairly DYI handy, it's not a big job to install a new DLP chip (or LEDs for that matter) into your DLP rear projection TV. Do a BING search on the internet for the make/model of your TV and something like "how to change the DLP chip" in that make and model. There are plenty of YouTube videos on line that make the procedure very clear. If after watching the video you don't understand the procedure, that's an indication that you shouldn't attempt it. I've replaced two LEDs and the DLP chip on my Samsung 65" TV. That might seem like a bad thing but if you consider that the TV was 7 years old at the time and these seem to be the only parts that fail, it was worth it to more or less make the TV like new again. When you search for the parts, watch out for sellers with low part price but ridiculously high shipping cost. I found that Sears.com had the best price and shipping times for these parts.
Aug 20, 2014 | Samsung HL-S5087W DLP TV
My samsung tv model hl-t6187s has no red
The red LED chip has burned out. Samsung purposely overdrives the red LED to make the colors look better and the red one usually fails from heat.
Apr 18, 2014 | Polaroid Televison & Video
Replaced lamp on samsung dlp - will not turn on - color wheel is intact but will not move - it sounds like TV is trying to start up but after three tries all three LEDs turn on - is this possibly a bad...
No,the tv colors wheel it is also dead or lose connections somewhere,because there no movement at all and all the LEDS indication lights are flashing and not giving power voltage to the tv colors wheel part at all.
Jun 22, 2011 | Samsung DLP HL-P5663W 56" TV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
TV went out, then came back on. Colors way off, no red .This is an LED tv. can it be repaired, or not?. What is the average years of use, with this type of Tv?
Yes,but it could be the incomming broadcasting cable itself,it the cause?Take another tv,test it out with that incomming broadcasting cable,see,if that tv also lost the red color?Yes,than the LED tv have a bad tv Tuner signal board,replaced this incomming tv Tuner signal board,will solved this problems.The average years are 9-10 years,with average of used like 10 hours a day.That how long the LED screen panel will last,but the electronic PCB boards circuitries are a difference story.Those parts on the PCB boards circuittries could last for a couple years are less.
pC
Nov 30, 2010 | Samsung 61" Slim-Depth LED DLP HDTV
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
Electro Med Services...
