Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
DISC STUCK IN COMPUTER
I CAN NOT OPEN THE DOOR (DRAWER) OF COMPUTER TO GET IT OUT.
    Scholar:
  • 105 Answers
Look on the drive of your system. There is a very small emergency eject hole on the drive. unfold a paper clip make it straight and then insert that paper clip in the small hole of the drive and the tray will come out. Remember do this with caution by switching off the machine
Posted on Jul 17, 2009
My Loewe DVD drawer is stuck closed with a DVD disc inside. How can I open the drawer and retrieve the disc?
Use a knife blade and gently pry the door open, it will work have done it more than once.
Nov 21, 2016 | Loewe Televison & Video
How do I open my disc draw it is stuck with a disc in it
I have had success by putting the computer on end with the disc
drawer facing upwards. then gently tapping the drawer as you hit the eject release
Nov 05, 2014 | Lenovo IdeaPad U260 Laptop Computer -...
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
We have a DAEWOO dvd and vcr player. We have a disc stuck in the player and the open button isb't working. Have tried turning off, turning on, holding down the button,nothing seems to work. Can't even...
I'm not familiar with this item but most have a mechanical eject just for this purpose. Look for a small hole on the front either on the disc player drawer or next to it. Unplug your machine from the power outlet. Straighten a paper clip and push it in the hole. It should open for you.
Mar 13, 2011 | Computers & Internet
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
CD DISC IS NOT SPINNING
Check the cd drawer sometimes the position switch is not detecting the drawer completely closed.
It could be an obstructing object stuck behind the drawer door who prevent the drawer to close completely.
Spider Guy
Jan 11, 2010 | Audio Players & Recorders
Stuck disc drawer rca model drc8312n
If there is a tiny pin hole in the front a straightened paper clip does wonders. Simply insert to release the drawer. At least that's how it works on computers ;)
Mar 28, 2007 | RCA DRC8312N DVD Recorder/VCR
Computers & Internet Logo
80 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
