Question about Brother LS-2125 Mechanical Sewing Machine
The needle will not grab the bobbin thread
I know it does work, because when I first turned it on it did work with their thread and needle,but when I changed the thread and new needle(it bent) it just does not want to bring that bobbin thread up!!
  • 7 Answers
I had the same problem- the needle should be in right, as there is a flat side that won't allow you to go in any other way without thoroughly screwing things over.
What kept happening to me is that my bobbin case kept popping out... open it up and make sure it's in correctly, mine sometimes will click twice instead of the usual once. So push hard! Also, make sure that you leave a trail on your lower thread long enough for the top thread to grab!
Posted on Jul 31, 2009
    Problem Solver:
  • 9 Answers
Double check the needle position when you put your new needle in. It is so easy to put them in backwards or sideways when learning a new machine. Also try checking the thread path of the thread, that it is not wrapped funny.
Posted on Jul 17, 2009
How the bobbin loads and works with the top thread.
Turn the machine wheel slowly to watch the depth that the threaded needle travels so that it meets the approaching hook-point of the bobbin holder. Point should almost touch the needle side and grab the thread just above the eye and wrap it all the way around the bobbin and holder. If the needle extends too far, it will jam. Not far enough and it doesn't reach the turning hook.
May 02, 2016 | Kenmore Sewing Machines
Needle cant grab thread in bobbin
Make sure you get a new needle, put it in RIGHT. usually flat side to back. Make sure your bobbin is turning in the case CLOCKWISE
Usually it is a bent needle, or it is in wrong. Also, make sure your thread in going through the eye of the needle, and not twisted around the needle.
Mar 22, 2014 | Sewing Machines
My bobbin thread won't come up with the needle. so, I can't sew. how do I fix it
First, make sure the needle is installed correctly. Then when you thread through the needle, it should go through the hole so that the thread basically lies inside the groove that runs down the side of the needle. These two steps are critical to being able to pick up the thread properly!! Typically the thread feeds from the left side or some from the front.
Secondly, make sure the bobbin is loaded correctly and firmly attached in place. The thread should just hang off the outside of the bobbin.
Hold onto the upper thread and manually turn the machine through the start of a cycle. When the needle goes into the top plate and down toward the bobbin, a hook should grab the top thread, rotate it about straight down (6 o'clock position) and then release it to grab the bobbin thread. Continue slowly turning the machine manually until you see (hopefully) the thread from the bobbin. Use something thin to pull both threads to the rear, under the foot, and all should be good. When you first start to sew, you might need to hold onto the top thread so it is not pulled out of the needle.
My guess is if you have done all the above, you could have a timing problem that needs to be adjusted at a repair shop.
Mar 08, 2014 | Singer Sewing Machines
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Jan 02, 2014 | New Home HF-106
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Singer 6235 - needle not grabbing bobbin thread
Make sure of 4 things. One, that the correct needle length and diameter is being use in the machine. Second, make sure you are turning the flywheel the correct direction and third, and fourth, that you have the Bobbin inserted correctly and spinning in the right direction. when picking up bobbin thread.
Cheers,
Embroidery Services
San Diego, CA
Sep 19, 2017 | Singer Sewing Machines
When running the machine, the needle does not grab the bobbin.
check your needle to see if it's damaged
make sure you have a 3-5 inch tail on the bobbin thread
then make sure you have a 3-5 inch top thread tail, then hold the top thread tail in your fingers (away from the needle) & turn the handwheel on the right hand side of the machine slowly letting the needle down in the bobbin area & see if the bobbin thread will pick up that way
Sep 27, 2010 | Singer 3116 Simple
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
634 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
