Question about Culligan Tools & Hardware - Others
Under sink tank on older water filter onlyy produces 2 qt at one time. it use produce 1 gal. we have lime iron promblem water 3 flter culligun system under sink water filer system over20 yr old filters have been replaced
  • 28 Answers
I am assuming based on your description that the system you have is a reverse osmosis system. If this is true, you most likely need to recharge the air pressure in your RO storage tank. I have included step-by-step instructions below. If you find that your tank is not holding air or the tank will not empty completely, the bladder inside the tank may be broken and the tank will need to be replaced. I have included a link to our selection of RO tanks as well. To recharge the tank you will need a bicycle tire pump and a tire gauge that will be capable of reading below 10 psi. If you don’t have one that reads in single psi increments, then a meter that starts at 5 psi will work.
http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
1) Close the cold water feed valve (if you can’t locate this on your system, you may be able to turn off the cold water to your sink)
2) With the RO tank valve on, locate the valve stem on the bottom or side of the tank. (this will look like the air stem on a bicycle or car tire)
3) Remove the stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave the RO
faucet open throughout the entire procedure)
5) If the current tank pressure doesn’t empty the tank, apply tire pump to valve stem
and pump a few times. Flow will increase and then gradually decrease as
pressure equalizes. Do not overcharge the bladder during this procedure.
6) Repeat step #4 and #5 until tank is completely empty. (Tank is empty when additional
pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5
& 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem
10) Open cold water feed valve.
11) The water is useable immediately; however, tank will take a few hours to completely fill.
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Posted on Aug 01, 2009
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Red water light has come on for the first time. water chamber is full of water. Iron is not producing any steam what could be the problem ?
Add white vinegar and calcium carbonate produced inside the iron will dissolve after 1 night.
Enpty the tank and it is all clean.
Dec 09, 2014 | Sears GC-822 MP3 Player
6 stage ro system under counter style will not stop draining or producing ro water at all I removed unit changed 3 pre filters and a post polisher now I gotta problem How long will this unit run to fill...
If the RO is not shutting off and there is no water from tank there are several things to check.
1. The product water tank is probably low on air. The tank may be full but no water will come out. Put enough air in tank to force out all the water then reset air pre-charge to 7psi for 3 gallon tank.
2. The capillary tube / check valve of RO system is bad. This puts back pressure on membrane to help create water.
3. The Automatic shutoff is not working, causing the unit to run constantly.
I would have to know what model RO it is to narrow down the problem further.
Depending on the Membrane production 10, 25 gpd, etc. and the TDS of water it may take 24 hrs to fill the tank.
RJ
Oct 07, 2011 | Culligan Under Sink Water Filter
I have a 3 filter undersink system that says Reverse Osmosis on the tank. It is a 2 1/2 gal. tank and i get , maybe 2 qts out of it now. I have been replacing the filters as instructed.
The storage tank probably has low air pressure. On a 3 gallon RO tank empty the tank completely of water and adjust tank pressure to 7psi.
RJ
Apr 22, 2011 | Culligan Under Sink Water Filter
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
I need instructions for changing the bladder on an under sink reverse osmosis system
Some RO storage tanks have the capability to change the bladder. Unless the bladder has a hole in it there is no reason to replace it. Air can be added to adjust the pressure. My suggestion is to just change the whole tank with a different style.
RJ
Oct 22, 2010 | Culligan Under Sink Water Filter
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
A drain tube in the water dispensing module constantly has some water flow. What is the purpose of this drain and how can I eliminate the water loss.
A reverse osmosis system drinking water system will waste a certain amount of water for every gallon it produces.
1. The higher the TDS (total dissolved solids) the higher the ratio of waste water to product water.
IE: An RO on TDS of 1000ppm may require 7 or more gallons of water to waste to 1 gallon of product water. TDS of 100ppm will have about 3 gallons of waste to each gallon produced.
2. It also depends on the Membrane capacity. Membranes for residential RO systems come sized from 7-75 gallons per day. If you are a heavy water user and have a low producing membrane the RO may not shut off until it gets to rest at night and fill the tank.
3. There can also be a problem with the automatic shutoff on the RO. When the tank fills up and the pressure equalizes across the system the ASO (which is just a simple diaphram system) shuts the water off to the system.
4. If there is not enough pressure in the RO tank the tank may fill up but there may not be enough back pressure to shut the ASO off. So the waste and product water go down the drain and it runs constantly.
RJ
May 21, 2010 | Culligan Under Sink Water Filter
Have a kent r/o system dont know how to hook it up is there any way someone can help
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 13, 2009 | Culligan Under Sink Water Filter
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
To recharge RO System Tank:
3) Remove stem cap.
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
Mar 19, 2009 | Culligan Under Sink Water Filter
Tools & Hardware - Others Logo
465 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
