Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
My compressor fills up. I use it for awhile and it never kicks back on giving me no pressure to shoot my nails. Any clue what the problem is?
    President:
  • 1,273 Answers
Yes... it is the pressure control switch. Unplug the compressor and take the cap off of the switch. Look at the contacts. Check for carbon deposits, loose or dropped off contacts and similar. If the contacts are carbonized, you can clean them with a fine sandpaper or an emery board. With the machine unplugged, you should be able to manipulate the contacts with a screwdriver to get a better look at where they should meet, and determine that there is nothing frozen in there. Manipulate the on/off switch and check to make sure that the off position disengages the contacts..Sometimes, sadly, you won't see anything and have to just replace the switch. There are settings that can be adjusted within the switch, and can make a difference, but you will need the switch directions to make changes to them successfully. If you have the switch directions, you can try to adjust the switch.
Hope this helps, --W/D--
Posted on Jul 19, 2009
Will only shoot one nail then I have to wait 10-15 seconds for it to reset. How can I fix it?
You may have an air supply problem. There needs to be an air regulator on the compressor so you can set the required air pressure for your nailer and project. You also need to verify the CMF output on your compressor is what your nailer calls for. If your compressor isn't large enough for the nailer, it will shoot one or two nails, the wait for pressure to build up . It will need to be high enough to operate per nailer requirements.
May 08, 2015 | Air Tools & Compressors
Why wont my hatachi nail gun shoot 1 3/16 nail all the time
Has the tool been lubricated properly to Hitachi's recommendation? Is the airline pressure running about 90-100 psi? If not try giving it more pressure. Sometimes the compressor may have too smaller receiver (Tank) for what you are trying to use it for, leaving the tool unable to return the piston/driver to top dead centre.
Sep 13, 2014 | Tools & Hardware - Others
Air gun "clicks"
Sound like o rings are bad. If you don't know how to rebuild it then have a tool repair shop rebuild it.
Jul 27, 2013 | Campbell Hausfeld 2" 18GA Brad Nailer
Why does my compressor trip the breaker after filling with air
1 of 2 things #1 the pressure releive valve that lets the pressure of the pump when it kicks off is stuck closed so what is happening is when the compressor kicks back on its under a load and trips braker. #2 your braker is to small for the compressor.
Jan 11, 2012 | Craftsman Air Tools & Compressors
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Shoots 2 or more nails at a time
Happened to me awhile back...just load few nails..it tends to shoot to many when you load it full. break a section in half load it and it should shoot just fine.
May 27, 2010 | Porter Cable BN18200 2" 18 Gauge Brad...
Rigid Compressor with nail gun. problem won't recycle or kick on. I have to bleed air to 40 psi before it kick on
The pressure switch is out of adjustment, it could have vibrated that way. It's the box the govener linage hooks to. It could be bent too. The pressure valve still works as it will kick in at the lower than normal pressure. The pressure swith may have to be replaced if it won't adjust.
May 11, 2010 | Ridgid Compressor With Toolbox On Top
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Jan 08, 2009 | Stanley Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
129 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
