Question about Garden
I have bought a used jd f911 72 inch deck, runs
I have bought a used jd f911 72 inch deck, runs great in very good shape, when i use the mower for about 15 minutes it will shut it's self off completely, under the seat there are 3 fuses, the fuse in the middle[25 amp] will blow everytime. when i replace the fuse, i can cut again for approximatly 5 minutes or so and it will blow again, it does this over and over. any idea what is wrong. thank you.
  • 130 Answers
Does it have a elec clutch.if so clutch is pulling to much power. replace clutch
Posted on Jul 18, 2009
  • fr23487 Jul 18, 2009
    does it have a elec clutch.if so clutch is pulling to much power. replace clutch
What is a 2001 17.5 Craftsman riding lawnmower worth 42 inch cut?
Condition makes a big difference. Common defects noted when selling a mower are: seat is ripped up; hood is off; needs a deck or drive belt; needs a battery; discharge chutes broken or missing; or the engine smokes when running. If the mower runs (can be jump started) but has some or all the problems it should range in the $150 to $350 price range. If it doesn't run or will need repairs just to get it to mow the $150 is about all you should expect. If the paint is good, stored inside and deck cleaned after uses and doesn't have the problems and is in good shape, a mower of this age can bring $500 to $750. The more problems the lower the asking price should be. Another factor that can determine value is where the mower is at. The price of a mower in California may bring more than one in the mid west - supply and demand.
May 27, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a belt diagram for secondary belt on a john deere f525 with a 48 inch deck
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Thanks for choosing FixYa,
Kelly
May 04, 2011 | Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
I have a husqvarna tractor yth1542 xpt . When it has run for about 45 minutes it will not climb hillls.replacing drive belt didnt work.
It is likely that your transaxle just isn't up to the task. I suggest that you try to operate the machine on the hills prior to going on flat land. This is a huge problem with these machines.
Jun 29, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Need mowing belt for 54" deck
It appears there are two belts for your mower. The primary belt is JD part M143019 and secondary is M118685. Your traction drive belt is p/n M127523.
The secondary belt for a 54 inch C deck is M154960 the other belts are the same as above.
I have used these folks for replacement belts before.
http://www.mfgsupply.com/MowerBeltsJD.html
I hope this helps.
Jun 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I've just had the same problem
check the fuel cap for a vent it needs to be vented . the air displaces the fuel no vent on fuel try running with the cap off . if it runs the vent was clogged or the wrong gas cap
Aug 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
MTD 50" belt problem
Hello:
There May be a Pulley that the Belt is Not Routed onto.
Use the Breakdown at the Following Site Addy to Locate the Deck and Belt Routing Breakdown.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Mtd LAWN MOWER PART # 753-05201 SERVICE...
Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
