Question about Sony Playstation 3 (PS3) Console
80010201 Error code and controllers won't connect
Used a movie the other day and it updated my firmware and now my controllers will not connect to the system with the wire or wireless.
In the 60gig ps3 it was the CWI-001 board located under the sd mini sd/ cf / m pro board and above the usbs. I replaced mine and controllers, wired and wireless Internet work fine.
That fixed my problem I hope that this helps. Good luck
Posted on Sep 02, 2009
Why is my magicolor 4650en showing service call c025
Konica Minolta Magicolor 4650EN Error Codes
Code
C025
Display
CONTROLLER ROM
Description
Controller ROM error (Configuration information error)
• Lead error of destination setting file is detected during the printer starting.
Remedy
1 Reboot the main body. 2 Check the PRCB connector for proper connection and correct as necessary. 3 If this error message is displayed after update of firmware, conduct the firmware update procedures again. 4 Change PRCB.
Feb 16, 2018 | Office Equipment & Supplies
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
Iomega screenplay firmware
you dont't update firmware. screen play dx latest firmware lot of bugs and not respond remote controller after 30min playable movie.
Aug 16, 2012 | Iomega 35039 1 TB ScreenPlay DX HD Media...
ERROR 2131 WHEN ON ITUNES
According to the support page the firmware update fixes the iTunes
issue with “The attempt to burn a disc failed. An unknown error
occurred (2131) when you tried to burn playlist to disc for blank CD-R
media. the region code error for DVD movie playback.
NOTE Please DO NOT USE THIS UPDATE FOR A TOSHIBA LAPTOP the computers
may have the same optical drive but the firmware updates may not be
identical and flashing with the wrong firmware may damage your drive”.
This isn’t just the Toshiba Equium A200 laptop getting an error of
2131, the other notebook’s manufacturers also established the source
of the problem and they have to provide a firmware update to download
and fix this problem. The best thing you can do is wait until Toshiba
provide a firmware update specifically for the TSST TS-L632H version
TO01 drive in your laptop.
Please let me know if you have any fuhrer questions or concerns.
Thanks.
Apr 25, 2010 | Toshiba Satellite Pro L300 Notebook
Ps3 error 80010201
this error means that a cable is unplugged or some thing like that: last night, my ps3 got a YLOD and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3, I got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
80010201 Error message appears. Please help..
this error means that a cable is unplugged or some thing like that: my ps3 got a ylod and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3 and got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
Im my PSP Some games will play others won't what give?
Need to upgrade the firmware...sony needs firmware updates to play new games, add features...and attempt to slow piracy. Ro up grade your system go to settings and network update...if you do not have a wireless network to connect to you can download the updates and put on a memory stick from sony.com
Mar 15, 2008 | Sony PlayStation Portable (PSP) Console
Sony Playstation 3 (PS3) Console Logo
1,186 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
