Televison & Video Logo
r
rose oconnor Posted on Apr 22, 2016
ALL I WANT IS THE CODES FOR A CITIZEN TVS - Televison & Video
I have a radio shack 5 in 1 remote. I need set up
0281,0288. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Can a sony rmt-b107a control a citizen television
Check these codes. 035,024,071,083. If you cant synchronize these codes, try some other setup codes to Citizen brand TVs. If you wish to get more codes, check this link. There is setup code list to different other brands of remote controls. Never stick on Sony brand remote itself. Only mind the brand name to your TV; not the remote control.
I have a Citizen flat screen TV model LT 2010. I just want to use my Jumbo Universal Remote Control but I dont have the codes. can you give me the codes for TV so that I can control my Flat...
here are some tv codes that you may find for your citizen tv model.the list are 002, 112, 319, 402, 407, 502, 512, 701, 805, 906. aside from those code click this universal remote control which have tv codes it might have compatible to your unit.make sure the remote control was properly set up so that the tv unit must recognized the codes. good luck i hope it will help you.
I have a rca converter and want to know if there is a code so i an use it on my citizen tv....i have lost the book of codes it comes with.
Citizen tv.Codes are 005,007,014,037,080,148,182,177,186,195,198, 274.These are 100% correct codes came out of the RCA DTV coverter box sheet itself.
Will a universal remote control work for my citizen tv. It is an old model - JCTV1372S and is there a code Thank you L
Yes , it will work but make sure you get a remote with the capability to control a Citizen TV.
The codes are different for each universal remote for example:
TV Citizen 0060, 0039, 0280, 0030, 0056, 0046, 0092, 0186 may work for one brand of remote but not all. check online for a specific brand, see if it controls a citizen tv, then program in the codes as per the owner's manual and it should work.
Need codes for a citizen jdvd3841
Hello S Wakely,
Here are the Citizen codes for you
Citizen 011,027,033,064
hope this helps you out.
Cheers Little Dish Fitter
1helpful
5helpful
4answers
W-URC3110 ONE FOR ALL REMOTE
These codes are used with Citizen TVs
0002, 0502, 0906, 0112, 0512, 0520,
0115, 0701, 0402, 0805, 0407
2helpful
UNIVERSAL CODE FOR A CITIZEN TV
Unfortunately, the codes you use with a universal remote are specific to that model of remote (it's not like all Citizen TVs are "0105" on every universal remote everywhere for example; the same TV might have a different code on each different model of remote), so we won't be able to give you a specific code to try.
However, you can try doing a "code search". Most models of universal remote allow you to search for the code. It's usually something like entering a special code (like 9998 or 0000) and then repeatedly pressing a button until your TV turns off or changes channel -- when it does, you know you've hit the right code and can stop. Look for instructions on how to do the code search in the manual for your remote.
9helpful
3answers
What are all the remote codes for the citizen tv, is there a web sight
001 / 004 / 008 / 009 / 042 / 053 / 058 / 105 / 109 / 177
These are the codes for citizen models, try one till you find the one for your citizen TV.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
