The reasons for it may be several ones. Let me go from the one with higher probability to the lower one.
1. Flash is stuck. It is the most comon reason, and more easiest to confirm. When pressed the shutter (or pressed the flash side button in P mode) you hears a repetetive click noise, and the flash won't pop up. If this happens, the flash is stuck.
Sometimes is solved when at the same time you press the shutter button, with the finger (or nail) you gently pull it up. Once is up, check for dirty, or any residues (such as tape glue, sand or something like that) that stucks the flash.
Some persons apply a thin layer of lubricant on the side hinges. Don't put so much lubricant or oil because will get inside the camera, and cause other problems.
2. If not click sound is heard, the either the flash actuator relay or the DC/DC board (that provides power to the flash board) or the flash board are defective. This can be confirmed only in a camera repair shop.
If you need further support, please let me know.
Best regards,
Was this helpful?
Yes
No
6 people thought this was helpful
Popular Solutions for Canon Digital Rebel XT / EOS
i took off my lens to clean inside the camera and now the camera will not autofocus or work at...
(More)
i took off my lens to clean inside the camera and now the camera will not autofocus or work at all??? there was a black mark showing up on pictures...
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads...
(More)
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads around 13. There is also a pause indicating a slower shutter speed. Any suggestions?
Have Canon EOS Digital Rebel, get Incompatible JPEG format? erros on some pictures, not all. Tried...
(More)
Have Canon EOS Digital Rebel, get Incompatible JPEG format? erros on some pictures, not all. Tried several cards and seems to happen with all so don't think it is the card. Have no transferred pics to computer, only viewed on camera. please help......does camera need servicing or are we doing something wrong? Shooting high resolution.....
my canon digital rebel xt no longer powers on. it was working properly when stored in a case and...
(More)
my canon digital rebel xt no longer powers on. it was working properly when stored in a case and now it does not power on. I dont believe it was dropped or otherwise damaged. it may have been exposed to cold, but was in the house and at room temperature prior to being reused.
