Question about Samsung HP-T4254 42 in. Plasma Television
The parental controls on my tv have been turnes on and they are not allowing me to even watch g rated shows. i do not know the passcode. is there any way to reset the tv?
  • 304 Answers
With the tv off. On your tv remote Press "MUTE" 182 then Power quickly. This will bring the set up into the service menu. In each of the selections look for Factory Reset. AND only that selection. Select the reset and the tv will shut off. Turn on the set and you should be able to to select your channels. If you have NOT set your own code then try "0000"
Posted on Jul 17, 2009
How do I change Parental Control on ROKU?
Parental control is one of the features available on roku. This feature restricts the children to access the movies and TV shows based on the rating of the movies and TV shows.
Roku doesn't provide any true parent controls. But the parental control workaround is simpler one. Only a few channels on roku have the parent control. Such channels are Amazon Instant Video, Netflix, and Redbox.
Initially, you have setup your roku account and add the channels from the channel store by using the PIN.
    1.Sign in to your roku.com/link account.
    2.Click the update button which is next to the PIN reference.
    3.Then choose the choice "A PIN is required when using your Roku account to make the purchase or add any item from the Channel Store."
    4.Put the 4-digit PIN and save the changes. After that, you can watch the channel by installing them from the roku channel store.
    After finishing the watching the channels delete it.
    If you deleting the paid channels means there are no issues because you need not pay again for reinstall. For re-install it you have to sign in again.
    For some channels which have parental control, that doesn't require to delete the channel after watching.
    If you want more information about the roku call 1-844-965-4357 to get instant help.
Apr 07, 2014 | Computers & Internet
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
Red key on screen wont show or change channel
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Jul 14, 2012 | Apex Digital AT2702 27" TV
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
Oct 21, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
TV not activating Parental Control locks
Unplug the unit for 2 min and retry.
See if there is a factory reset in the menu.
These Tvs are notorious for problems, check here
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Dec 22, 2008 | TruTech PLV16190 Television
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
65
Nov 24, 2008 | Mitsubishi VS-55707 TV
I forgot my pass code for the rating for movie watching, How do I reset it?
When you get to the screen where it ask for passcode press the select button on the controller, it will take you to a screen to delete the passcode enter 7444 then it will prompt you for a new passcode and you can enter something you can remember. After you set new passcode you can go into parental controls to turn the feature off if you like.
Nov 07, 2008 | Sony PlayStation 2 (PS2) Console
Vchip
If you can get into the menu, and know the proper password, then you can change the parental control setting. If not then the memory chip may have to be replaced. Stargazer
Aug 05, 2007 | Samsung TXN2726 27" TV
Samsung HP-T4254 42 in. Plasma Television Logo
288 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
