Cars & Trucks Logo
T
Terrence Govender Posted on Apr 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the crankshaft sensor located on a nissan almera 2006 automatic SA.
jamessizer
Level 3:
  • Nissan Master 7,515 Answers
  • Posted on Apr 23, 2016
jamessizer
Nissan Master
Level 3:
Answers
7515
Questions
0
Helped
690372
Points
37181
2answers
2006 Nissan Almera. 1.6 automatic. Can I please get the cylinder head bolt torque settings for it?
Here you go, the year is close enough.
What are the Nissan almera 2004 1.6 16v cylinder head ...
Answers https://www.answers.com > What_are_the_Nissan_alm...
Feb 22, 2023 - THE NISSAN ALMERA 2005 1.6 16V CYLINDER HEAD TOURQUE SETTINGS. 1.Tighten 29N.M using the correct sequence. 2.Tighten 50°. 3.Tighten 55°.
1helpful
What are the effects of a faulty crank sensor on a nissan QG18 engine
what a great question!
no year told, no country , no car told just raw engine
QG18 comes in many types QG18DD,,1999 to 04
QG18DE, 1999 to 2007 QG18DEN is the natural gas version?
lacking all key facts.
I go GENERIC (full bore)
the answer is super simple..
causes spark misfire. (and scanned PCM see P03xx errors DTC)
loss of engine horse power. and wasted fuel.
or engine dead. fully and no spark at ALL.
why worry it at all.??? if scans are clean this is it if CKP does not trip CKP errors DTC
must we guess all of these and if yes why?
and more,
The QG18DE is used in the following vehicles:
the CKP and CMP sensors are the base line inputs for all spark and fuel injections and timing and timing advance of spark
if spark dies the PCM cuts all fueling dead( no crash&burns)
Will not shift 2006 Nissan Almera
the car needs service,
all you can do is check fuses.
then scan for DTC errors with OBD2 scan tool, P07xx orP17xx errors are trans errors.
the steps to fix or diagnoise any trans fills volumes,
but the maker of your car has book called FSM factory service manual and you can read the A/T pages, on what to do.
Nissan almera tino Crankshaft sensor location, please help as I need to change mine, already got part
U sure its the sensor..dont guess. Cud b an egr valve or vacuum leak. Car wudnt run at all w a bad cranksensor. Git car scand to target area
1helpful
Location of nissan almera tino crankshaft sensor
if you are under the car it should be on the firewall side. It is black piece or a light grey color.
Where is the crankshaft position sensor on 2006 Nissan Sentra 1.8s?
"The crankshaft position sensor (POS) is located on the cylinder block rear housing facing the gear teeth (cogs) of the signal plate at the end of the crankshaft."
did you clear the trouble code first and see if it returned?!?
P0335
Crank sensor location
Should be under crankshaft pulley .
4helpful
2answers
2005 nissan almera,1.5letre.. fault code po725
P0725 NISSAN - Engine Speed Signal
The P0725 Codes is triggered when TCM does not receive the engine speed signal from ECM.
The Engine Control Module (ECM) monitors the engine speed through the Crankshaft Position (CKP) sensor with the engine running, and send signal to the Transmission Control Module (TCM).
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes:
- Open or shorted CKP sensor circuit condition
- Poor CKP sensor electrical connection
- Check communication error between the ECM and TCM
- Failed CKP Sensor
Possible solution:
Very common problem with Nissan vehicles, usually replacing the Crankshaft Position sensor takes care of the problem.
Keep us updated.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
