Question about Directed 1100d Car Audio Amplifier
What is the difference between slave and master on a car amp
  • 34 Answers
Its asking if its the main doing the driving or somthing driving it
Posted on Jul 17, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
How to connect it as a slave. there is no guide to follow on hd label
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
May 20, 2011 | Seagate Cheetah 15K5 Ultra320 SCSI 146GB...
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
I need to put my hard drive into an enclosure but I cannot figure out if I need to switch it to a slave before adding it to another computer
i have done this alot for my customers and its really simple. if you look up your drive and get the jumper settings for it and set it to cable select or master in a one drive enclosure it will work well. i do not recommend putting it on slave because some enclosures will not recognize the drive, I do recommend having an enclosure with a fan on board and an external power switch. the reason it the fan will extend the life of the drive and the power switch eill allow you to power it on and off without having to flatten (power hot swap) the drive. Hot swap is ok but this is better than just unplugging the drive. removing the power from the drive keeps the drive in park until you re-power. as long as the drive is "parked" it is les likely to cause read/write sector errors.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
What is the position of the link do I need to change to master/ slave etc
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
My WDC WD2500JS hard druive is getting noisy and slow. I am thinking of replaceing it before it dies and at the same time do a clean install of Win7. It is now XP. Can I make this drive a slave until I...
first up
uninstall a few unnecessary programs
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
second
yes you can make it a slave
you will have to change the setting in BIOS for master/slave aswell as the jumper settings
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
make sure the computers motherboard will support windows 7
wait until you get the new drive before before connecting your hard drives to master/slave
depending on the amount of drives your computer has you might have to change letters on all drives
naming of the hard drive you might be able to change the name opening windows explorer navigate to the drive then right click on the drive then select rename
Dec 15, 2010 | Western Digital 250GB WD RE SATAII...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
Where is bleed screw on master slave cylinder
I guess if you could decide which you are talking about, the master or the slave, it could be answered. masters do not have bleed screws, slaves do. slave cylinders at the back wheels have bleeders which are on the inside of the backing plate, slave cylinder in the front caliper has a bleeder which sticks out the top of the caliper. clutch slave is a horse of a different color in a saturn. may have to buy a whole new master/line/slave assembly.
Oct 25, 2010 | 2001 Saturn SL
Directed 1100d Car Audio Amplifier Logo
173 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
