Question about Logitech Cordless Mouse
How do I install/begin using wireless mouse? It worked before then batteries ran out and I can't remember if I need a disc to re-install.
    President:
  • 2,923 Answers
Most Logitech wireless mouse are just Plug-n-Play and it does not require any driver installation. All you have to do is to plug the wireless dongle to the computer and connect the mouse. Here's what you need to do:
1. Make sure that the batteries are fresh or fully charged.
2. Turn ON the mouse using the switch button.
3. Locate the connect button on the dongle (receiver) and then press it once.
4. Hold down the connect button underneath the mouse for 5 secs. and then release it. And the mouse should work.
If the mouse is not responding, then hold down the connect button on the dongle and on the mouse at the same time for 5 secs. and then release them both. Move the mouse around.
Hope this helps and have a great day!
Posted on Jul 17, 2009
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and...
namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
Aug 22, 2011 | HP Wireless Optical Mouse
How can i install a wireless keyboard and mouse to an Acer Aspire, windows says it's install but only the built in keyboard works while the wireless mouse does work
Fred I have an acer too Im running Linux and use a LogitecM305,,see if you can get one,,it has a small receiver which plugs into the usb port and remember to put a battery in the mouse itself and also to switch it on ,,there is a small switch on the underneath
Jul 19, 2011 | Acer Aspire One AOA150-1435 PC Notebook
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
After I changed that bateries in my dell m787c mouse, it wouldn't work with my keyboard anymore. How do I fix this problem?
Please read complete post before beginning. I am offering more than one solution,
Try reinstalling your mouse with the disc that came with it. You should be able to simply place the disc in the drive and click install. If you do not have the disc. You could try going to:
> Control Panel
>Depending upon the version of windows you use, (you may find the install/uninstall in different places)
> Click on Uninstall
> Click on the mouse program in the menu that pops up...be very cautious here so that you do not acciddentally uninstall a program that you want or need.
You will be given the option to uninstall/repair/install
> Click on repair.
You might also click
>Start
>In the search box type compatibility issues
Open whatever file it gives you and check for issues for your mouse or keyboard.
Finally, check again whether the batteries are actually good. ( I would bet you have already done this)
>Right click on my computer
>Right click on Properties
>Click on Device Manager
>find your mouse in this list(usually mouse and pointing devices)
>Right click the correct mouse
>Click Update driver and follow instructions from there.Click on search my computer for device driver first try. ( you may or may not need an update.
If neither of these options work: please write back with your operating system ( windows 7, Vista 32 or 64/windows Xp, etc. and also the make of your keyboard and model numbers if you have them.
Dec 16, 2010 | Dell Wireless Keyboard Optical Mouse w0147
How do you install new batteries in my Kensington PocketMouse 72214
i have the mini m. for awile want to install in another notebook dont remenber how> helpppp
Sep 23, 2010 | Kensington PocketMouse 72214
Wireless mouse stopped working after lap top battery ran out
Remove the battery and put it back. Try to reset. Use a mouse pad.
Jan 26, 2010 | NexxTech NWOMMI Mouse
My ge wireless mouse will not work. Everything lights up and I push the links and turn on but it does not work. I have a dell and have newest windows.
just to be sure, make sure you have new batteries in the mouse. Then go ahead and unplug the usb adapter for that mouse and then plug it back in and see if windows detects it properly.
If it does see if it works then, if it still doesn't work then the mouse is bad and would need to be replaced. Also if windows detects it but can't find the drivers, you'll need to use the disc to install the software for it.
Jan 11, 2010 | GE Wireless Optical Mouse
Wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
201 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
