Question about Whirlpool LER8648P Electric Dryer
I have a whirlpool LER8648PWO dryer that runs but doesnt heat. What could be the problem and where would you look first?
  • 1 more comment
  • runnerbl Jul 17, 2009
    Have looked at breaker. It looked fine but reset anyways. That didn't fix the problem. Will get someone to check the other items in your link. Are these components easy to distinguish? thanks for all your help.
  • 5,911 Answers
The following link explains how to troubleshoot a dryer not heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat Most dryer heat related problems are attributed to poorly installed, kinked or clogged exhaust vent ducting. Pay particular attention to the section that discusses ventilation and make sure your dryer interior and ducting are clean. Leaving a dryer in a clogged condition will not only decrease the drying efficiency of the appliance, it will also cause repeated failures of any components you may replace and is a fire hazard.
The first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If you have any questions about this repair, or require additional assistance please let me know.
Posted on Jul 17, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 17, 2009
    The components are easily identifiable. On your dryer all you have to do is unplug it and remove the back panel. The heating circuits are on the lower right hand side (as viewed from the rear). The heating element is located inside the heater box. The Thermal Cut-Out (TCO) and Hi-Limit Thermostat are located on the outside of the heater box. The TCO is at the end opposite the heating element terminal (top of the heater box), while the Hi-Limit Thermostat is adjacent to the heating element terminal.
    You can view an exploded view diagram of your dryer at searspartsdirect.com. Just type in your model number and look under the "Bulkhead Parts" heading. The TCO/Hi-Limit Thermostat repair kit is listed as item 5 (Part # 279816). Both components are included and should be replaced if one or the other is found to be defective. Failure to do so may result in premature failure of any parts you replace. The heating element is listed as item 17 (Part #279818). In the majority of the cases, the TCO fails due to overheating. NOTE: When you type in your model number, the last character is a zero, not an "O".
    Other sites you can check are appliancepartspros.com, pcappliancerepair.com or repairclinic.com. Sometimes these sites may offer better prices. Just use the part numbers listed above.
    I hope this helps you.
You electrical outlet gives out to you only 110, to correct the problem have the electrician correct the wired contention to the backer, it has to be crossed, not direct, look into the book if you have done it your self :-)))))) fire the electrician who fixed the hookup! Good Luck
Posted on Aug 17, 2009
2 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Whirlpool dryer works but will not tumble
It sounds like the belt is broken. Take a look a the video at this link and see if it helps you. Sure hope so and best wishes.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
Posted on Sep 11, 2009
How to open Whirlpool LER8648PWO to change door switch?
Stick a screw driver between the top and the body and pry up,the top should open up and you will be able to see the switch.
Mar 02, 2011 | Whirlpool Dryers
Dryer runs but doesnt heat up
On a Whirlpool, it has been for me the coils are broken...it can be fixed by undoing the belt, 'popping' the top pnl up with a screwdriver, lean the front pnl down then move the drum forward to get to the coils. You MUST use a crimp type connector as these are nickle wire and won't solder easily. Saves a lot of money and will run forever. Definitly unplug it first! Duh!
Dec 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer model LER6620PQ0 dryer runs, but will not heat
If drier runs and doesnt heat, it can be one of two things. 1)The over temp. th/stat has activated. Possibly it can be reset. or 2)the actual element is faulty, which would need replacement.
Sep 21, 2009 | Whirlpool Dryers
Sep 11, 2009 | Whirlpool LER8648P Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Air not heating up in whirlpool dryer
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 25, 2009 | Whirlpool LER8648P Electric Dryer
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer LER8648PWO won't heat
Oh boy. First you need to open the unit to expose the heating area. When he was in the drum he must have disloged a thermostat control. You'll have to find it and fix it. Also check the door switch.
Nov 24, 2008 | Whirlpool LER5636P Electric Dryer
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
IT RUNS BUT DOESNT HEAT
It's either a heating element or thermostat gone bad. This link will help you locate what to look for. http://www.partadvantage.com/store/categories/wp/LGR6620PQ0
Mar 20, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER8648P Electric Dryer Logo
936 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
