Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Electrolux Oxygen Canister Vac
The power head on my Canister Vac has stopped spinning.
I have tried the reset button but that has not fixed it.
Is there a quick fix that I am missing?
  • Anonymous Nov 23, 2007
    Power head also stopped working. I discovered that the polarized pin on both sections of the wand are missing. I am going to give hell to Electrolux and then contact the consumer product safety commission and report a electrocution hazzard.
  • Samant1 Feb 18, 2008
    The power head would turn off, then restart when the brush head was swiveled. Now the powerbrush no longer works at all.
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Posted on Jan 08, 2008
Where is the reset button on the oxygen 3 canister?
please see the video: proceed with common sense and repair. God bless you.or go www.electrolux.com go customer support and download your instr. manual and see the reset button.
God bless you
Jul 15, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My oxygen will not pick up pet hair out of the. The brush rotates
Your brush may not be spinning try pressing the reset button on the back of the power nozzle, it that does not work you may need to change the belt.
Bob
eVacuumStore.com
Mar 18, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Our Electrolux canister vacuum just stopped working when we were vacuuming the floor. The power does come on when the power head is attached but as soon as the power head is removed the power shuts off. I...
The guardian is the most complex vacuum I've ever worked on. The technology exceeds all others. Usually the problem is with the computer board in the handle. My suggestion is to take it to the nearest Aerus Electrolux dealer. http://www.aerushome.com/storelocator/
Dec 31, 2009 | Electrolux Guardian Bagged Canister Vacuum
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Feb 19, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
735 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
