WOBD2 COM is World OBD2 tools mall providing Car Truck Diagnostic Tool OBDII EOBD JOBD Scanner Odometer correction ECU Chip Tunning Auto Key Programmer Locksmith Tool and Other...
Reset Volvo service reminder indicator or maintenance messages after changing oil, filters and inspecting brakes and suspension.
Press and hold trip reset button,
turn on the ignition,
wait for the yellow warning light to start blinking,
release the button and wait for confirmations sound,
turn off the ignition,
turn the ignition back on to check if the service message is gone.
This procedure will reset messages:
TIME FOR REGULAR SERVICE
ENTRETEIN REGULIER NESECC
SISTEMA MOTORE PROSS.TAGLIANDO
STANDARDWARTUNG DURCH FUHREN
TAGLIANDO SCADENZA
TIJD VOOR REG SERVICE
WYMAGANY PRZEGLAD OKRES.
ZEIT FUR REGELM. WARTUNG
This also works in any other modern Volvo car, like: C30, C70, S40, S60, S80, V40, V50, V60, V70, XC60, XC70, XC90.
More details over here: Volvo reset service reminder indicator
FUEL PUMP IN FUEL TANK.YOU DID NOT TELL ME WHAT VOLVO YOU HAVE S40 V40 C70 S80 V70 V70XC.YOU CAN ACCESS FUEL PUMP BY TILT REAR SEAT FORWARD REMOVE.FOLD BACK TRUNK COMPARTMENT CARPET.REMOVE FUEL PUMP PROTECTIVE COVER.THIS PROCEDURES FOR VOLVOS I JUST MENTION AT THE ABOVE INFORMATION.
Mileage on timing belt, depends on year ? make (volvo) model (c70) and engine size?. heres a couple of mileage readings,the 1998 c70 with a 2.3 turbo engine is due every 70,000 miles. the 1999 -2001 c70 with 2.3 turbo is due every 105,000 miles. the 2002- 2004 c70 with the 2.3 engine is also at 105,000. the 1998 c70 with the 2.4 engine is due every 70,000 miles. the 1999-2001 c70 with the 2.4 engine is due every 105,000 miles. the 2002- 2004 c70 with the 2.4 engine is due every 105,000 miles. god luck hope this helps.
90% of the Time..Code 1171 is an 02 sensor. Other 5% Is a Mass Airflow Sensor.. And Last .. Fuel Pump.. If engine seems to run fine.. its an O2 sensor.. Thank you
Sorry for the severe delay. I am personally going back to answer your unanswered question. I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Timing Belt Diagrams with Marks for the Camshaft and Crankshaft that you will need. It also has numerous other helpful diagrams for use.
Again my apologies... Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Answer
Ijust tried this with my 2004 C70 and it worked.
Cheers!
To reset your service light here are the steps.
1. Get in your car and shut the door. 2. Put your key in the ignition 3. Turn your ignition key to position 1 4. Push in your Odometer reset button and hold it in while holding it move the ignition key to position 2 while holding down the odometer reset button. 5. After couple of seconds of holding the button down and the key in position 2 your service light will start to blink once that happens let go of the reset button and start the car.
This should reset your service light and a service light on your Volvo C/S/V70 cars from 1999 onwards.
