Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Network status is "offline" . I just had to reinstall my router. I then had to remove the old network and add the new network for each of my laptops. I think I need to do the same for my HP officejet 6500 wireless printer. Any ideas how i remove the old network and add the new network (both the old and the new have the same network name).
Most likely you need to set a new IP address on the printer, because your new router likely has a different Ip address than your old one.
Posted on Jul 17, 2009
What does status code 13030 mean
"Clear the Cache": Tools > Options > Advanced > Network > Offline Storage (Cache): "Clear Now"
"Remove the Cookies" from sites that cause problems: Tools > Options > Privacy > Cookies: "Show Cookies"
Start in Safe Mode to check if one of your add-ons is causing your problem (switch to the DEFAULT theme: Tools > Add-ons > Themes).
See Troubleshooting extensions and themes and Troubleshooting plugins
Nov 13, 2012 | Compaq Computers & Internet
Laptop to Wireless Printer
you try this device another machine so what happen problem is same or solve
Jun 01, 2012 | Brother MFC-J265W Wireless All-in-One...
I am online but appearing as offline to my friends
if you are indicating facebook or any other social network just check you status option maybe it's off. if you are indicating YM or any other chat programs also check your status options maybe it's off. let say it's still the same try to open other website to check if you have a internet connection. if you have a connection try reinstalling your YM or other chat program, let say its facebook or ther social network try using other internet browser like firefox, google chrome, opera, etc.
Apr 10, 2011 | Computers & Internet
GOT A NEW ROUTER NOW MY LAPTOP WILL NOT PRINT. IT SAYS NETWORK STATUS IS OFFLINE
You may simply need to lower the security level on your new Router. Some Printers/Laptops will not connect to routers that are set to WPA2 security.
Nov 23, 2010 | HP Officejet 6500 Wireless All-in-One...
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Aug 04, 2009 | Canon PIXMA MX850 Multifunction Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Do not have access to the internet
which windows is installed in ur laptop if its windows vista go to network & sharing center click on manage wireless network remove ur wireless network from the list the add the network again and u will be able to connect wirelessly incase if it does work with that go to the device manager & uninstall the wireless network adeptor then click on scan for hardware changes onces the driver is reinstalled u be able to reconfig ur wireless network easily
Aug 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
454 people viewed this question
Seeker5211
Seeker5211
