Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
SOURCE: lost book for it and need code for bush dvd player and how to enter codes please help
hello i need the code for tv {RCA}and how to work it please help
SOURCE: bought urc-7515 code 0037 for bush telly only
The original remote for a Bush uses several codes for various buttons! I doubt that many of the universal remotes would have the sohistication to do this. Does your remote provide a 'Learning mode? If so this is the only way to get it to work close to its original.
SOURCE: What is the 'One4All' remote code for Celcus TVs?
Try these codes. If it do not help you, Try code search method.
0147 0135 0250
0257 0310 0394
Code Search Method
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
SOURCE: I AM LOOKING FOR THE CODE FOR A BUSH FREEVIEW BOX ON AN URC-6230/ 6231 WHAT IS IT ?
0856/0843/0786
SOURCE: I need the manual codes for RC: URC-1660.
Check the following linked site. You might get more codes to check. Visit the site named 'Electro-help'
for more details. Click this link. View it in Timeslide or Flipcard
option, which can be selected from the drop down box menu by the Sidebar tag,
at the top left corner of the display window. You can also click the Home tab to see the latest
updates. It will make search
easier. There are more than 1400 posts
to different brand TVs till now. Setup
proceedings and code list to different brand remote controls also
included. Pull up older posts or do a
search by type in the Brand Name of your device in the Search Box,
at the top right of the display window.
Check this link too.
