Question about Sony PlayStation 2 Slimline Console
My slimline ps2 switch is jammed
My power switch for my slimline ps2 is jammed when i push the button it will just get stuck
  • tutuy Dec 13, 2007
    my slimline ps2 switch fell off in inside wat should i do
  • 67 Answers
If you have warrenty by all means get it repaired , but if not go onto ebay buy the switch unit and Turn off the ps2 while on to discharge it , make sure you touch your hand on a metal object every 15min open up the ps2 and on the right or left should be the switch and you pull on the ribbon VERY LIGHTLY and it should pop out (cable)and you should be able to take out the switch and then replace switch and connect it .Close the console and see if it works
Posted on Dec 09, 2007
My sister dropped my ps2 and the power button got jammied
My power button got jammed as well and I used a small flat head screwdriver to pop it out and it was fine. If that doesn't work you might want to tack it to a video game repair shop or try to open it and see if the button broke off and is keeping the button inside the system.
Oct 27, 2013 | Sony PlayStation 2 Slimline Console
Ps2 power light stays red
hello eric i've repaired a few ps2 most of the time it's been down to the power switch if not the power switch then the ribbon cable attach to the switch
Feb 25, 2010 | Sony PlayStation 2 Slimline Console
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slimline powerbutton touchsensor broken
That PCB is pretty basic, so if you are good at soldering tiny parts, IN PRINCIPLE, you should be able to fix it. That said, you must be certain that the switch itself is working and that the PCB is OK. Use a multimeter to check connectivity and functionality. To avoid the hassle, yes, it might be a good idea to just buy a new PCB, but be sure to be careful when disconnecting and reconnecting the ribbon cable, as it is very fragile.
Apr 13, 2009 | Sony PlayStation 2 Slimline Console
It wont turn on at all
The same problem occured to my slimline ps2. I opened it to find that the power switch inside had broken of. The only option is to get the switch soldiered back on or replace the tiny circuit board that has the switch.
Jul 13, 2008 | Sony PlayStation 2 Slimline Console
Getting ps2 micro switches realigned
micro switches is wat turns on and off the PlayStation2 and they make the Cd tray come out and resets the ps2 the buttons are the green button on the front of the ps2 to restart and turn on the ps2
and the blue button is at the bottom of the green one the blue button makes the Cd tray come out and the last micro button it at back of the ps2 its a black button that turns off and on the ps2
your rating is highly appreciated
Jun 23, 2008 | Sony PlayStation 2 Slimline Console
My PS2 On/Off Button is Jammed
this site should help you get the case open.
you need to get in there and find out what's causing the button to stick. It could also be the button on the front of the drive that's stuck. if that's the case you might be able to pop it back out once you get the outer PS2 case off using a knife or a small screwdriver.
Mar 25, 2008 | Sony PlayStation 2 Slimline Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
