You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainageYou have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
You can't post conmments that contain an email address.
Full parts list here, but from my 52 years in the hospitality trade, Hobart washers need professional diagnosis and repair. Your unit has a 'Chemical Detection Box', but only the engineers will know how or what it detects.
also see page 6, items 17 and 18, and 20 Timer Relays. Part 17 is specific to detergent and rinse, so replace that first.
Try running the hot water into the sink immediately before you turn on your dishwasher. That will get hot water from your heater to dishwasher faster & help with the sanitizing cycle heat
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
I thought it was designed for domestic bleach at 5.25%, and looking for a solution of 50 ppm of sanitizer and rinse water. Either the elbow is blocked, or the silicone tube in the pump has collapsed. Use rubber gloves and face protection when working on chemical tubing.
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
