Question about Kenmore 98702 Stacked Washer/Dryer
Washer won't start - Kenmore 98702 Stacked Washer/Dryer
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Kenmore 98702 Stacked Washer/Dryer Logo
323 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
